Posted by: weissmarine
Description: Contact Capt. Greg Weiss with Weiss Marine at(843) 647-8407 or visit us www.weissmarine.com for more information.Make: YellowfinModel: 36 Center ConsoleLength: 36 ftPrice: USD 149,500Year: 2004Condition: UsedLocation: Charleston, SC, USAHull Material: FiberglassNumber of Engines: 3Fuel Type: Gas/PetrolTotal Power: 750 hpYellowfin 36 Center ConsoleDescriptionNew on the market. Powered by triple F250 Yamaha's with four blade props. Great electronics and rigged to fish any tournament. Raymarine E120, Garmn 740S (touch screen). Premium stereo - Rockford Fosgate Amp. Huge fishing platform, 38 Rod Holders, Outriggers, Downriggers and many more great features that Yellowfin represents. Heavy duty AmeriTrail triple axle trailer with surge brakes.Number of Engines: 3Primary Engines: Outboard-4SEngine Make: YamahaEngine Model: F250Engine Year: 2004Engine Hours: 400Total Power: 750 hp Boat NameLike 2 FishDimensionsLOA: 36 ft 8 inBeam: 10 ft 0 inMaximum Draft: 1 ft 8 inDisplacement: 12000 lbsDeadrise: 24 ° at TransomEnginesEngine Brand: YamahaEngine(s) Total Power: 750 HPEngine Model: F250Engine Type: Outboard 4SYear Built: 2004 Fuel Tanks: 1 (510 Gallons) ConstructionCored reinforced hull bottom with molded in stringers, stiffeners, and partial transversebulkheading.Topsides are cored fiberglass. Deck is cored molded fiberglass, joined to hull, andchemically and mechanically bonded (through bolted).Electrical 12vDC and 120vAC with four group Optima 34M AGM batteries. Engine start/ ships servicebatteries are located in leaning post rigging compartment in heavy duty battery trays, securedwith brackets. Stranded thermoplastic shielded wiring to selector/parallel switches located samecompartment. Stranded thermoplastic shielded wiring to circuit breaker panel and Moritz DigitalControl Processor located inside center console, starboard side,and to micro switch controlpanel at helm. All DC equipment is adequately circuited and breakered. Battery charger forbattery maintenance- Promariner 15 amp 120vAC with a battery charger inlet on leaning post,port side. Tinned multistrand wire to battery charger twenty four inches away.Electronics & NavigationRaymarine E120Garmin 740SRaymarine 215 DSC VHF (2)Dytek ST500 TempRitchie CompassAudiovox Sirrius Satellite Radio & RemoteSony XpodRockford Fosgate Amp P80004Kicker ZX750.1Raymarine DSM300Raymarine SeatalkSimrad Autopilot AP26JL Audio SpeakersIsotherm38 RodholdersTelescopic Outriggers Additional EquipmentAmeriTrail aluminum triple axle float on type trailer, with surgedisk brakes on front two axles, and spare tire/ hub assembly.Kiekhaefer Trim tabsMarine toilet under console12Vdc outlets port and starboard at transomFresh water wash downSalt water wash downPort and starboard under gunwale lightingGunwale, t top and transom mount flush rodholders (38)Sunbrella weather coverCoffin box with matching seat cushion and electric hatch liftFor and aft spreader lights at T topFish box pump outGrand Slam outrigger bases at T topLayoutCenter console open fisherman type with chain locker in forepeak, accessible from ring deckhatch (gunwale). Single level weather deck with storage under. Center console with port sidedoor opening, and portable toilet inside. Aft of center console is leaning post/ bait well with aftseating, above with is a T top with upper steering station with engine controls and leaning post/seat. Transom is closed with transom door, starboard side out to built in swim platform.Safety/Regulatory Equipment: Navigation lights(8) Adult type II life preservers located under forward under gunwale port and starboard storageshelves behind snap on retailing netsB1 fire extinguisher loose inside consolePull out boarding ladder at transom, stbd sideManual signal hornOrion Alert/ Locate visual distress signal kit- expiredFirst Aid kitOil Discharge placard mounted inside consoleTrash Disposal placard mounted inside consoleRulemate 1500 duel mode bilge pump at aft bilgeRulemate 2000 duel mode bilge pump at aft bilgeType IV throwable buoyant cushion under center consoleGround TackleAt bow chain locker – Galvanized 15 lb. lightweight type anchor with an adequate length of3/8” galvanized chain, and an adequate length of ½” twisted three stranded nylon rode.Underwater Sections & Running GearHull has raked stem, hard chine “V” bottom, with lift strakes forward of a ventilation step,transom stern with a built in outboard bracket and swim platforms. Hydraulic trim tabs were inplace. Running gear consists of triple counter rotating gasoline outboards with four blad props.EnginesTriple F250 Yamaha Engines. 4 Blade props DisclaimerThe Company offers the details of this vessel in good faith but cannot guarantee or warrant theaccuracy of this information nor warrant the condition of the vessel. A buyer should instruct hisagents, or his surveyors, to investigate such details as the buyer desires validated. This vessel isoffered subject to prior sale, price change, or withdrawal without notice.
Boat Loans By Excel Credit.
More...
More...
