In 86 I bought a Mazda b200 pickup truck brand new off the lot. It was my first brand new vehicle ever. I drove used cars up till then. At that time I was convinced that Amsoil (same as Moble1) was the best thing ever for an engine. Never used it before. So - I left the mineral oil in the engine for the recommended 2000 miles - and put it in. At 60,000 I took off the valve cover to adjust valve lash, and the first thing I noticed was how freaking clean everything was. Zero deposits.. the inside of the valve cover was as clean as the the day it was made. Also... no adjustment was necessary. I had read that engines with 100,000 miles were just broken in. So, I also drained out the manual 5 speed overdirve transmission and put in something like 0-90w
gear oil in the thing. WOW! It shifted so slick! I could REALLY tell that that transmission was slicker that you know what! In the cold it was amazing! So I figured - put it in the rear end too. I can't present any data to prove that the thing was more fuel efficient, but it certainly seemed to be. I was bragging to everyone I met.. about this synthetic mythical fluid - but more times than not, I'd get someone that would tell me: "You just wait.. you will have leaks." I said: "that is a myth - not true." Well to make a long story short, after 150,000 Miles I ended up with leaks in the engine main seals, the transmission seals, and the rear end seals. At $6.00 - 9.00 dollars per quart - I switched back to cheap mineral oil. However that truck did go over 300,000 miles.
Oh.. I should mention I also used Slick 50 in it.
Any comments about what you think is appreciated.
