They are cracking from the lug nut holes . Very very small . I don't think it is from overloading but I do use the hell outta it .
Ask whoever changes the tires if they have any idea what caused it.
Mike
They are factory wheels . I do use a big 6' Trackless snow blower on the rear in the winter .I swear I did not see them , last time I did my Pre op check . I wonder if that could have caused it . I know the blower is damn heavy .
Guess I better plan on ordering up a new set of wheels soon .
We've had some luck with grinding out the cracks and welding them shut. Die grinder to get the holes back round. We've also welded on a reinforcment ring around the entire center hole and redrilled through the original holes and through the ring.
My guess is the blower might be the issue....
Do you use a good torque wrench when you tighten them? Improper torque can let the lug nut act like a wedge when you spin the wheels. Can you see them on the inside also?
