I have an '06 Accord and I had to run some wires through the firewall. It wasn't the easiest thing to do, but it wasn't that bad. Although the instructions said to remove the lower dash panel, I did not want to risk having a clip break on it so I left it in place. The lower panel under the dash (over the driver's knees) comes off relatively easy. From there you can push a couple of wires through with the main wiring harness through the rubber bushing in the firewall. Honda was generous with their use of those black wire ties under the hood. I was able to put the additional wires through existing wire ties. You may have to cut the existing wire ties and put new ones on to hold your wires in place. That seemed to be the tightest part of my wiring.
Let me know if you need more specific info. I don't have that car with me, so I was going from memory (which could be defective
). I can always stick my head under the dash and under the hood to take a look see.
