Which Stihl Chainsaw? MS211 C-BE or MS192 C-E
The MS211 is a "Homeowner" series saw, it weighs 10.1 pounds, develops 2.3hp.
The MS192 is a "Farm & Ranch" series saw, weighs in at only 7.4 pounds and is less powerful at 1.7hp.
Both have the Easy2Start system.
Both have the Anti-Vibration system.
Both have their Intelli-Carb system.
Both have 16" bars.
The MS211 is priced at $299
The MS192 is priced at $369
I'm leaning toward the more expensive, less powerful MS192 simply because its 2.7 pounds lighter. To my mind that lighter weight is a significant advantage.
For the most part I do not do anything with a chainsaw that qualifies as lumberjack work, I don't use wood in my fireplaces so I don't have a wood pile that I need too worry about. So I don't believe that the lower horsepower of the heavier duty saw will be any real handicap for my uses.
My current Stihl is 20+ years old and failing. Dropped it off at the shop today and the guy said if it needs any parts then I might be unable to keep it running much longer. So clearly its about time.
Any advice? Thoughts?
pixie
Get the 192. It has a real oil pump.
I have the 192 and also a 210 which is the predesessor to the 211. Already replaced the carb on the 210. Not one problem and many more hours on the 192.
I burn 6 cords of wood a year which I cut myself and also do a lot of trail clearing and woods maintainance.
pixie
And I forgot to say... the dealer doubled the warrantee period for buying a 6 pack of the 'Ultra' 2 stroke oil. Don't know if that offer is still available.
Jim_S
I'm with you, the lighter the better.
Have you looked at the MS201? It's also from the Farm and Ranch series, 2.41 hp, 8.81 pounds. I have no idea of the price though.
Jim
They did that for me last summer when I bought a hedge trimmer. Not sure if it's still offered.
Jim
$669
Honestly can't justify that amount given the amount of use the saw will get.
Well I got a call from the shop.
Repair estimate on my 20+ year old saw is roughly $175.
I just ordered a new saw. The MS192 C-E. They didn't have one in the store but they had 2 on order set to arrive next week. I told them to put a SOLD tag on one of those with my name on that tag.
300 H and H
I think you may have gotten in a hurry here....:whistling:
I have been using a Stihl MSA 160C....
It's the lithium Ion battery powered saw. I thought it was but a toy... Untill i cut 5 pickup truck bed full of brush with it! Dang no noise no gasoline to mix. Just charge the battery and fill it with bar oil.
Cuts a little slower than a small gas saw, but it weighs half as much. I am really starting to like the little bugger....:wink:
