ST4 back from the dead
Puckle
Had to fix windscreen wipers before painting new cab - the old spindles had completely rusted away along with the windscreen surround.
New Bug spindles (111-955-215/F ) fitted ok but were not quite the same and required new brass end pieces making for the link arms and small rotation stops spot welding to window surround.
The wiper motor was shot as well (brush mounting plate had rusted away) but I had one at the back of the shed that fitted after re-drilling the mounting holes - I think it was off an Audi A3 but not sure.
Puckle
Everything stripped off now so I can get at the chassis - needs new rear cross-member and new front axle carrier spindles but otherwise not too bad considering its suffered well over 50 Scottish winters!
Puckle
Right, that's got most of the chassis problems sorted, legs straightened, new body mounting rails, new front axle pivots and pins, new rear cross-member, new front spring mounting plates and new side plate fitted to axle housing. I need to turn it upside down now to complete the welding then shot blast and paint.
Puckle
finally manged to start getting paint on after hours of stripping and shot blasting- had to send the chassis out for the blasting as my compressor blew up just as I started and filled the blast pot with oil - very helpful!
Decided not to risk shot blasting ally panels so have used several gallons of paint stripper - managed to find one that still contains some DCM so still works - the picture of the two panels shows one with Nitromors and one with Sysnstrip - the Synstrip worked twice as fast and required fewer coats but still took forever to get through the ten layers that had accumulated.
The plan is to get everything covered with two coats of epoxy primer, and then assemble the whole body for primer filler/fairing then topcoat - hopefully the weather will hold out for long enough to finish the painting before it gets too cold.
Puckle
Finally got the body assembled and painted, driven me nuts with wrinkling, micro blisters, runs etc. - you just get one panel right and it then decides to pickle up somewhere else and it's back to the wet-n-dry to cut it all back. Still a bit disappointed with the finish but run out of patience now - I'll get back to mechanical things for a bit before I start to paint the hood, door slam plate etc.
All the panels have been assembled with polysulphide sealant to keep the moisture out - certainly sticks well - I had to dismantle all the rear panels and re-do them as when I came to fit the roof the alignment was miles out - that's a problem with an all bolted assembly - it goes together slightly different every time!
Snowy Rivers
Fabulous job.....
Don't beat yourself up.....this machine is a sweetheart..
You have done a fabulous job of bringing it back from the valley of the shadow of death........:thumbup::thumbup::thumbup:
Puckle
Been doing a bit of machining as a nice change from cleaning and painting - these are new suspension bushes in Delrin, an ultra high density acetal that is self lubricating, so does not need grease everywhere - may still re-fit the zerks though in case the spindles start to corrode.
Snowy Rivers
So nice to have machine tools.....
These projects are almost impossible without machine tools.
Mine would have been stopped dead without the lathe and the mill.
Looking great
Another great material for bushings is UHMW...."Ultra high molecular weight" polyethylene
Wears like iron....
Puckle
p****d off with poxy pickling paintwork so thought I would do a nice bit of detailing and fit the luggage rails and mats. I'm sure using Rhino liner paint would be more practical, but I don't think it would look as good as the ribbed rubber sheet and Ally trim. I also put the graphics on the side - I had downloaded the correct template from this forum, but it was easier to order them with a standard font rather than get the pdf file printed off and it seems a fairly close match.
Puckle
Starting to put windows back in - tricky little job that turns out to be. Watched some video's on you tube with clever people putting them in with bits of string but couldn't get that to work at all - best method seemed to be putting the rubber around the opening then inserting the window from outside and using the strip inserting tool to pull the rubber out and over the glass whilst pushing it in. Inserting the sealing strip was ok with the correct tool but very tight - I could only find new rubber with 7mm web, slightly bigger than the original and supposedly only suitable for minimum 100mm radius corners (snow-tracs are 68mm). Got 5 originals back in so far, now waiting for some replacements to turn up that I have had made.
Puckle
Partially stripped down the engine to paint it and found the carb manifold heat riser tube blocked - read some stuff on Samba about burning the carbon out with oxygen but decided easiest way was to drill 5mm hole and spin a length of rod through it with the end bent over - this worked a treat and it was a simple job to weld the small hole up afterwards.
Not having much luck with this new format Doc has changed to - keeps saying pictures are too large - I'll try again later.
Puckle
Also, finally received 14 new small wheel rims that I ordered back in July - these are made by Vlukon in Netherlands and are slightly more robust than the originals - 3mm steel rather than 2mm - see drawing attached
Cidertom
Chionophile
what did you use for the tires on the new small wheels? And were the Vlukon rims a part that can be ordered, or were they special built for you?
Puckle
Hi Tom, I've used Trelleborg 100/100-4 (4.00-4) 6 PLY T539 TT - I've not had any experience with these but they are the correct size and are 6 ply so should be ok - they are also quite cheap over here - £26.00 each.
The Vlukon rims are a standard product - e-mail Hans Haas <h.haas@vlukon.nl> and he should be able to quote you - rims are ref 6991 and can be had in various RAL colors - I had silver and they were approx. 30 euro's each pair
