I brought the cat home to Silverdale on 5 July for summer maintenance and inspection. Somewhere between Ellensburg and home the passenger door came open and being a suicide door slammed into the side of the rear cab. I had installed rubber bumpers on both sides, after having had the same problem two years ago when the door opened on the freeway and broke the tempered safety glass in the rear cab side window. But it hit the bumper so hard it flexed the door and broke the safety plate glass. It's always something.
Everything else looked good on inspection. No safety or reliability issues. Just cosmetics and corrosion control.
The new glass is on order. I decided to rebuild both doors since I have to tear one apart anyway. I will try to figure out why the latch won't hold it closed. I had also been thinking about putting bigger windows in the side of the rear cab for better passenger visibility. So I ordered two of those while at the glass place. What started as a small repair job is now a major project. I'll cover that in the next post.
While I had it apart I installed the back up camera I bought last winter. it was pretty easy. I got a wired unit that just has a camera about the size of a walnut, and a 4.3 inch monitor. The cable length is about 16 feet total. it has a 4 pin micro plug on each end and a ground and hot lead. I wired it to the instrument circuit so it is on all the time.
The camera is mounted on the bottom of the hitch cross member. the wire runs up the left side of the tunnel, under the dash board, up the left side of the windshield to the space above the windshield centered on the drivers side. I don't know how, but the wire was not an inch too short or an inch too long. It was just right. Goldilocks!
I made my own mount for the screen. The supplied arm is fairly long and had a small base. I wanted to mount the screen close to the head liner over the windshield with Velcro that will stick to the interior carpet soundproofing/insulation. That way I don't have to drill any holes.
There are distance bars on the screen. The red bars start at about 2 feet from the back bumper.
I kind of had to put the camera on the back of the chassis because the rear cab is removable. A cat with a permanent rear cab would be able to put the camera higher. I think the low mounting will be ok. It is fairly well protected. I'll find out this winter.
