SOLD
Selling my 1959 Tucker 222 Kitten. S/N 159642. Motor # S107812F. Hour meter shows 461 hours but I do not believe it is correct. It needs a battery and the mechanical fuel pump rebuilt or replaced. I have a kit and at least 1 additional mechanical fuel pump but today's gasoline ruins the rubber diaphram and valves in a very short time. I would convert it to an electric pump. The pictures show the left hand track split for access to the fuel pump. I have replaced the original glass bowl sediment filter with an in line filter because it leaked. I have the old glass bowl. I have added a carburetor air filter although it may not have had an air filter. Other than that it is 100% original with the Ford Anglia motor and drive train. I have a few old track rollers and links. The head lights need to be rewired. The original gauges are there and working but you cannot see them in the pictures due to glare. Someone added the 2nd oil pressure gauge. The sweeps were added by a previous owner and it appears that it once had a small plow mounted on the front and the body springs were eliminated. The in tank fuel level float is stuck. 3 different paint colors can be seen - orange, reddish orange, and blue. The sno cat is currently located in Cobden Illinois 62920. $8500. Additional pictures may possibly be found on this site under GYPSY.
