Ford 550 backhoe leaking hydraulic fluid
wildskies.com
Anybody ever changed the backhoe control seals in a Ford 550?
Mine are leaking. I hope that I can do the job without taking the backhoe off the tractor.
Thanks!
are you talking about spool control valves usually they are a simple in the vehicle change . just a bunch of o rings
wildskies.com
spool control valves. It looks like that they are held in by two allen head screws. I kinda figured that it would be (hopefully) 25 cent o rings.... The problem is that it is a real tight place to work. The frame of the backhoe has access holes that I can get one hand through the opening at a time.
Chip
