Mitsubishi blowing smoke
waybomb
If it's a turbo seal oil leak - you will want that taken care of right away. A runaway diesel is a pretty cool thing to see and hear, so long as it is not yours!
you could have some oil leaking on the hot side of the turbo but cold smoke is normal i would have injectors checked as if you have one leaking it will burn a hole in teh piston in no time flat. most coolant induced smoke coming into a combustion chamber will happen when shut off and still warm but in some rare cses i have had cracked heads leeak a little coolant in over night
