Not a good day so far.
Busted the belt on my 6' mower deck on the big tractor trying to mow the field. Felt some vibrations, by the time I turned around to see what was happening there was no more vibrations and no more spinning blades either.
Brought the tractor up the back path to the workshop and tried to take off the cover plates. Went to the right side belt cover: Bolt #1, no problem. Bolt #2, no problem. Bolt #3, not any way to get that loose. Figured I'd come back to Bolt #3. Went over to the left side belt cover: Went to the right side belt cover: Bolt #1, no problem. Bolt #2, no problem. Bolt #3, not any way to get that loose. WTF!!!
You were having the day that I had on Saturday .... everything that I touched broke!!!!
The tire came off the wheel on the little, 25 gallon, tow behind sprayer. Got out the little compressor and tried to get it blown back up and on, the compressor wasn't building any pressure. Later found that what passes for a seal on the piston is totally worn out. The sprayer is full of chemical but I finally get it jacked up and braced. I get the wheel off but break the retaining clip that holds it on. I tried everything I know of short of starting fluid to get that tire back on the bead but can't do it. Not to mention when I was filling the sprayer in the first place, the fitting blew off the end of the hose. I was so glad when the sun set and I could close the book on Saturday!!!!
Transferred the herbicide from the little sprayer to the big sprayer on Sunday, built more and got it put out and also sprayed 150 gallons of insecticide. I'm having a bad time so something is going to DIE.
I fixed the hose today. The compressor is pretty much junk. I'll get the tire fixed tomorrow and then ... we'll look for something else to break!!!!
Country living is good ... sometimes.
