1800 rpm yanmar
bill w
I bought a 10k northern lights genset for the yanmar 3 cyl liquid cooled motor for a project. i'm looking for anyone that has info on how to convert it to a non fixed 3000 rpm. it is a model# 3tne78 ac-ad. thanks, Bill w
JimVT
I have the yanmar 3 cyl in my gator if you need pictures
what are you planning?
bczoom
Super Moderator
Does this help? I'm thinking you remove the regulator spring and replace it with a something rigid like a turnbuckle then attach a mechanical cable to the top of the regulator handle.
iu
mla2ofus
As I see it w/o the spring the governor would rendered inoperable. might need a stronger spring but that might cause other problems.
bill w
i'm going to use it in my hustler groomer I bought.it had a twin diesel ruggerini air cooled in it.i wanted a motor I can get parts for without calling Italy....and don't worry,lots of pics coming up. Bill w
cabinboy
BCZOOM Is correct the regulator spring is maintining 1800 rpms for the generator speed at all times the idle screw is set to 1800 rpms also.
