please post your snow trac/ snow master interior cab upgrade photos and ideas
mchowser
Hello,
I would love to see interior pics of upgrades to the cabs of snow cats. Insulation? instrumentation, paint, design, upholstery, flooring, customization, safety items, storage, racks, heaters, electronics, etc.
Post anything of interest if you have the time or inclination.
Thanks,
Mark
Left side of my dash with additional controls and custom labels.
Custom shift knob. I also had a custom horn button made up with my serial number, the logo and the model number.
Ice Queen
This is the interior of mine - the guns were borrowed at the time, it now has a Sterling submachine gun.
mchowser
Thanks for the posts!!! Anyone else?? I know pics are a pain to post, but the info can prove to be invaluable.:smile:
Mark
NorthernRedneck
:hammer:Bob....I thought you would have learnt your lesson by now......you're gas guage still reads empty.:unsure:
:whistling::whistling::whistling:
clhsmith
not sure how i got the above picture to appear but on the second attempt it did. the hardwood extension is for the stereo andthe plate above it is removable for the mobile radio.there is not enough depth behind the dash otherwise.should have shrunk the picture somewhat i guess but i had enough trouble just geting it here!!!
I like the MERCURY steering wheel center. I presume you are paying tribute to the fleet footed Greek god Mercury because the Snow Trac is so fast over the snow? :whistling:
mchowser
Wow, that looks great! Nice addition with the stereo. Can you hear above the sounds from the track when the snow is moving? Did you sound proof the interior?
Thanks for the post!
Mark
check out the lever on he left i'm guessing that's for the parking brake if so good place for it
clhsmith
we used built in vacumn cleaner muflers to negate the noise coming through bthe heater tubes.they seem to work great. we plan to use a space age spray on sound deadner from "quiet car.net" to make the cab quieter.will lett hhe forum know how it works out. bad typist!! the fuse panel is new and moved to the middle of the underdash.the original fuse panel location you have to be a 6 year old child or a contorsionist to get at it with the seat and stearing wheel in place.
painted the intreior grey today used a 3-m product callled rocker shultz than grey enamel the 3m stuff is thick and soft should absorb the sound and the grey sould brighten up things also laid 1 inch foam board on the roof and back door next step will be seats and dash already have the cht gauge and hand throttle next to the choke but i need more gauges idiot lghts don't get it for me
got my non matching seat cushions in last night so i figured i would post some pics of the start of mu interior work i started bu shooting down my interior with a compound called rocker shultz than sprayed over it in battke ship grey gives the wall texture and the soft compound helps remove the harmonics when operating on hard surfaces. ive added a cht guuge i will also as time alows adding an oil temp gauge oil pessure gauge volt meter and a fuel gauge when the new tanks get here. I have also added a rifle mound for a carbine length survival gun normaly a 22 mag in the winter or a converted 1895 marlin 50 ak for the summer ii have 2 aluminum tanks being built to go back under the seats and i would eventualy like to lay 1/2 inch foam cab liner through the interior.
forgot the photos here they are
hendog
FYI, I can get snow trac seats made to copy the orig. It will have a bead at the edge and high density foam. They arent cheap to make I will do a whole set for 600 not including shipping from scratch. This will have low temp covering. I just did 2 myself and they turned out great!
Let me know if anyone wants a set.
for the way mine gets used mine wil work just fine but when i get around to raising the top i will be looking at thicker foam with 3 kids and the same amount of dogs the bead is just some thing to get riped off so i will continue with the smooth edges
