Rolling vs grass seed
USMC Veteran
GOLD Patron
I need to do a few things to the yard.
Kill the crabgrass (a different thread).
I also need to roll and overseed.
For a roller, I'm bringing in a 3-ton ride on paving roller (with tamper).
Should I overseed then roll or roll then seed later?
Why don't you core aerate and de-thatch first, then seed, then roll. Then you will have lots of dirt exposed for the grass seed.
Grass will look beat up at first but will recover when it gets warmer out.
This is my plan but I'm just going to use a smallish tow behind roller as anything too big will probably cause more damage on steep hills.
I only have a spike aerator. :( I was thinking of using that after everything was rolled (like pull it behind the mower every time I mow).
The lawn is relatively new (thus the need to overseed) so there's no thatch to pull out.
What's the issue with the steep hills and a larger roller? (I too have some hills... am I not thinking of something?)
Traction. If it's too heavy then you're going to spin out taking it up the big hills. It may also cut in or pull if you do it sideways. I only know this from trying to pull trailers and stuff up some of my lawn.
What's the minimum temperature required to get grass to grow?
If it's in the 50's during the day but hovers around freezing at night, is that too cold?
Brian,
Once your seed starts to germinate it can not freeze. I would wait some if you are experiencing freezing temperatures.
murph
Thanks Murph.
I'll hold off.
I was just thinking that it's so darn wet out there that it'll have plenty of water coupled with the fact that nobody walks/drives on it since it is so muddy.
I would just over seed and not roll the lawn at all. Rolling is for when you have ruts or high spots that need to be smoothed out. If you roll, you run the risk of over compacting the soil and that is what will kill your lawn. I almost never roll unless I need to get some ruts out of the lawn. Also, before you cut the grass for the first time this spring, walk the lawn and carry a spray bottle of florescent red marking paint. Spot any rocks that you will need to dig out when the ground starts to firm up. The frost will pull the rocks up from below and they can kill the mower blades quickly if you hit them. I raise rocks the size of potatoes and there is a bumper crop ever spring... :mad:
Junk,
Ruts and high spots is exactly what I have.
My plan was to roll but then pull the spike aerator behind the mower for the first several mowings to get some air back in.
