Ok Here is the scoop. Our local sar has a lmc 1200 10 man cab. I am looking for info from others. We are brainstorming.
It is a 300 6cyl cat has 110 hrs on the meter Runs and shifts well.
1st problem Speed
This cat has a high speed rear end in it. tops out 24ish mph at redline in high gear. We do not have the HP to pull the cat above 1st 2nd gear up a hill at 8-10k feet. Steep snow covered hills are not possible because 1st gear is to tall it just bogs. This is not a running issue this is a gearing issue. Cat runs out great. What are everyones thoughts on a reasonable way to gear the cat down to make the 300 perform at elevation. All the guys have ideas we are looking for the most reasonable bulletproof way to get it down to 12-15 mph.
2nd problem cooling.
This cat came with a 5 blade rigid blade fan. We took this off and put a 2 speed electric fan on for noise, and power. We like the fact the cat is quiet inside now. Butt now we are fighting a cooling issue. it is a 1800cfm 18in fan about the largest we can fit in the engine tunnel. It has a shroud to cover entire radiator. and it is set up as a puller currently. This on the cat today at about 40* was not enough to cool. Ideas to get more airflow to cool the beast. Thanks For Any and all ideas. Mike
1st problem Speed
