My Snow Trac engine has devloped a crack in the generator/oil fill "tower" at it's base where it bolts to the engine case. I have another one to replace it...
Does the fan shroud have to come off to replace it? And if so can this be done in the cat, or would it be easier to remove the engine?
The new part I have I took off a donor engine that I bought to some day build. It is a dual port type 3 engine and the Snow Trac has the single port type 2 engine. I mention this because the tin work/fan shroud is not quite the same. Lots of screws to remove around the back side of the engine to get to...
So what is the best aproach to replace the generator tower?
Thanks, Kirk
Thanks, Kirk
