I need some suggestions on the best way to remove/install steel track from the pontoons of my 63 443. Seems to me the best way is to get all pontoons off the ground and use the gears. The manual state "opposite set off the ground". Not quite sure. Seems like that would still leave one set engaged. Also considering dropping drive line to one set and elevating opposite of the one I will be removing.
