Go Back   Forums Forums - Off Topic Forum FUN > Snow Trac ST4, Kristi, Thiokol/LMC, Tucker, Bombardier & Other Snowcat Discussions > Snowcat Repairs, Parts & Problems Forum > THIOKOL/LMC/DMC Technical Issues Forum
THIOKOL/LMC/DMC Technical Issues Forum Technical repair issues & questions for Thiokol/DMC/LMC
Reply
Thread Tools Display Modes
  #1
Old 10-29-2008, 07:19 PM
gotyellow gotyellow is offline
Junior Member
gotyellow is on a distinguished road
Default 1800 hydraulic schematic
I am working on a LMC 1800 with blade problems. Have replaced hyd. pump and flow control valve. When blade fluid has warmed up the blade becomes super slow.
Hydraulics are seperate from main hyd.s, use pump mounted on engine.
Would like a schematic if one is available, let me know.
Thanks this forum is totally awesome.
  #2
Old 10-29-2008, 09:50 PM
Thiokol2track's Avatar
Thiokol2track Thiokol2track is offline
Thiokol2track is on a distinguished road
Default Re: 1800 hydraulic schematic
When you say fluid, what are you using?? Have you tested pressure , both hot and cold?
  #3
Old 10-30-2008, 10:49 AM
Junior Member
This particular customer is using regular hyd. fluid rather than ATF.
I haven't tested pressures yet, but have replaced both the pump and flow control valve, wondered if the problem could be in the elec./hyd. valve body?
Don't consider myself an expert so thanks far all the help.
  #4
Old 10-30-2008, 06:45 PM
It seems I had this problem before.....it was a elecric over hydraulic unit ....It had a small screw behind the elec. magnet that triggered the spool. for adjustment which controled flow. Not sure if this is whats happening for you. maybe post some pictures for us.
  #5
Old 11-02-2016, 09:38 PM
Hugh Hugh is offline
Junior Member
Hugh is on a distinguished road
I have a raidtrac snowcat 1800 are they rarely. where can i get information about them or pictures
  #6
Old 11-02-2016, 09:56 PM
MNoutdoors's Avatar
MNoutdoors MNoutdoors is offline
Tracked Evolution Central
MNoutdoors is on a distinguished road
Those other posts are 8 years old
But here is your link
http://www.raidtrac.com/
__________________
I had a conversation with dirt the other day, It promised me that when I die it's got me covered
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Hydraulic Schematic of Bombardier 302HD kgracey Snowcat Repairs, Parts & Problems Forum 2 01-21-2015 08:43 AM
Hydraulic Top Link vs Top-N-Tilt Melensdad Tractor Forum 8 11-29-2011 09:35 AM
LMC Trackmaster hydraulic oil bluffcam Snowcat Repairs, Parts & Problems Forum 3 05-09-2008 07:56 PM
ATTENTION ! Resisdent Hydraulic expert !! BigAl Oil, Lubricants, Engines & Misc Forum 20 06-26-2006 10:52 PM
Duramax 6.6 liter stops/limits at 1800 RPM's bczoom Cars, Trucks Forum 12 04-09-2006 08:43 AM
