Go Back   Forums Forums - Off Topic Forum FUN > Snow Trac ST4, Kristi, Thiokol/LMC, Tucker, Bombardier & Other Snowcat Discussions > Snowcat Repairs, Parts & Problems Forum > THIOKOL/LMC/DMC Technical Issues Forum
THIOKOL/LMC/DMC Technical Issues Forum Technical repair issues & questions for Thiokol/DMC/LMC
Reply
Thread Tools Display Modes
  #1
Old 04-30-2017, 09:01 PM
fritz's Avatar
fritz fritz is offline
Junior Member
fritz is on a distinguished road
Default New to me dmc 1200
I plan on tearing into the new to me dmc in the next few weeks, are there any known fatal flaws or problem areas to be aware of on these?
Thanks in advance
Sent from my SM-S820L using Tapatalk
  #2
Old 04-30-2017, 11:43 PM
PJL's Avatar
PJL PJL is online now
Default Re: New to me dmc 1200
I have an 88 LMC 1200.
Engine is a 300 CID straight 6 Ford industrial. Pretty reliable motor. Mine did crack a cam gear though.
Transmission is a Ford C6. Rear diff should be the OC12.
Provided it's been cared for there should be no major issues other than normal wear and tear on a 30 plus year old machine.
The Following User Says Thank You to PJL For This Useful Post:
fritz (05-30-2017)
  #3
Old 05-01-2017, 10:04 AM
Melensdad's Avatar
Jerk in a Hawaiian Shirt
Quote:
Originally Posted by fritz View Post
I plan on tearing into the new to me dmc in the next few weeks. . .
We all hope you document it with PHOTOS so we can see:
Before,
During &
After images
__________________
- Ayn Rand
The Following User Says Thank You to Melensdad For This Useful Post:
fritz (05-30-2017)
  #4
Old 05-01-2017, 09:59 PM
fritz's Avatar
Junior Member
@PJL it's in pretty rough shape, it had some electrical issues and needs a harness. but I did want a project.
@Melensdad I hope to document the resurrection as it goes along, and I'm sure that I'll be bothering all of you with plenty of questions along the way
  #5
Old 05-05-2017, 05:42 PM
fritz's Avatar
Junior Member
So does anyone here have a wiring diagram for one of these? Im a bit confused on this machine, I read somewhere in here that they stopped using aluminum cabs on these in '81. This one has an aluminum top and steel tub what gives? Any ideas?
  #6
Old 05-05-2017, 05:45 PM
fritz's Avatar
Junior Member
1 more thing, is it possible to disconnect the hydros on this? I don't trust the hoses at all, will pulling the belt on the pump hurt the rear diff?
  #7
Old 05-05-2017, 08:23 PM
PJL's Avatar
The 88 has a steel tub and aluminum cab. The doors are steel.
The hydraulic pump helps to cool the diff oil. Mine has the pump and cooler only. No hydraulics.
fritz (05-21-2017)
  #8
Old 05-06-2017, 10:53 AM
fritz's Avatar
Junior Member
Thanks for the info PJL. I think I'll keep the pump and cooler and ditch the rest for now. Would you happen to know how the vin #'s break down on these?
  #9
Old 05-11-2017, 08:33 PM
PJL's Avatar
http://www.pittauto.com/customer/pia...0%20CSG649.pdf
Look here for the engine manual.
I uploaded the small PDF. Click on the link for the full version.
The Following 3 Users Say Thank You to PJL For This Useful Post:
bobby wilkes (05-12-2017), fritz (05-21-2017), nikos (05-14-2017)
  #10
Old 05-13-2017, 11:27 AM
Dr. Zaugg Dr. Zaugg is offline
Dr. Zaugg is on a distinguished road
If you post the whole serial number I will look and see the year and run number.
The Following User Says Thank You to Dr. Zaugg For This Useful Post:
fritz (05-21-2017)
  #11
Old 05-13-2017, 11:56 AM
fritz's Avatar
Junior Member
@ Dr. Zaugg the cat # is d3a 1951. I don't have the engine # currently available
  #12
Old 05-21-2017, 03:17 PM
Your cat was built third to the last of 1983. That was run #338
The last 1983 1200C was serial number 1953
fritz (05-30-2017)
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
New to me lmc 1200 yooperman Snowcat Restoration & Modification Projects Forum 28 01-24-2016 11:42 PM
lmc 1200 tires mbsieg Snowcat Repairs, Parts & Problems Forum 1 11-24-2014 09:30 PM
Thiokol 1200 Needs some TLC tomelroy Snowcat Classifieds (For Sale / Wanted) Forum 0 01-12-2014 04:05 PM
LMC 1200 VS LMC 1500 mtncrawler Snowcat Adventure & Usage Forum 11 02-09-2011 02:12 PM
LMC 1200 Over Heating cleary THIOKOL/LMC/DMC Technical Issues Forum 7 01-02-2009 09:16 PM
