2007 Tiara 4300 Sovran
RSS User
Posted by: johnsearay
Description: Huge price reduction! Owner wants this to be the next 43 Sovran SOLD!! Owners change of plans, creates an awesome 4300 Sovran opportunity! Up until May, 2011, "Bad Bouys" spent her entire life on Lake Erie, her current owner brought her to Charleston and promptly had new bottom paint, including prop speed, installed before splashing her. He then added cockpit ac to battle the Carolina heat, also added a tinted EZ2CY drop curtain to make cooling the cockpit even easier. He also added Tracvision and a macerator with y-valve, then had both engines and IPS drives promptly serviced. The bottom line here is that "Bad Bouys" only has 211 hours on her Volvo 500IPS and she was an extremely well equipped boat prior to the added options previously listed, now she represents the best 07 430 Sovran value anywhere. If you are considering a 4300 Sovran, you do not want to miss this one! Doesn't need a thing, except a new owner! Engine room looks like NEW, as well as everything else on the boat! Boat Name BAD BOUYS Specs Warranty: 5 years Hull Shape: Modified Vee Dimensions LOA: 45 ft 3 in Beam: 14 ft 9 in Maximum Draft: 3 ft 7 in Deadrise: 17 ° at Transom Dry Weight: 26800 lbs Engines Engine Brand: Volvo Engine(s) Total Power: 740 HP Engine Model: 500IPS Engine Type: Inboard Drive Type: Pod Drive Year Built: 2007 Engine Hours: 211 Trim Tabs Tanks Fresh Water Tanks: 1 (110 Gallons) Fuel Tanks: 2 (375 Gallons) Holding Tanks: 1 (50 Gallons) Accommodations Number of single berths: 6 Number of cabins: 2 Number of heads: 2 Electronics Depthsounder - Raymarine ST60 Log-speedometer - Raymarine ST60 Plotter - Raymarine E120 Autopilot - Raymarine Autohelm ST6002 Compass - Ritchie GPS - Raymarine E120 VHF - Icom M504 Radar - Raymarine E120 TV set - 24 DVD player - BOSE Radio CD player Cockpit speakers Rigging Steering wheel Inside Equipment Bow thruster Electric bilge pump Battery charger - Charles Solid Power 500SP Air conditioning - 4 total units Heating - 4 total units Hot water Sea water pump Microwave oven Marine head - VacuFlush X2 Refrigerator Deep freezer Electrical Equipment Shore power inlet - 50 amp Cablemaster Generator - 11.5 KW Onan 175hrs Electrical Circuit: 110V Outside Equipment/Extras Cockpit cushions Cockpit table Swimming ladder Cockpit shower Electric windlass Covers Bimini Top - Complete enclosure with custom tinted EZ2CY drop curtain Manufacturer Provided Description The Tiara 4300 Sovran with Volvo Penta?s Inboard Performance System challenges every assumption about what a boat can be by changing the whole future of onboard performance while elevating enjoyment of the boating experience. On the 4300 Sovran, dramatically reduced noise and vibration allow conversations in comfort while underway. Because Volvo Penta?s IPS releases up to 25% fewer emissions, owners enjoy diesel power performance, economy and durability without exhaust smoke, noise or vibration. In fact, Volvo Penta?s IPS in the Tiara 4300 Sovran delivers 25% better fuel efficiency resulting in fewer trips to the fuel dock, increased speed, acceleration and extended cruising range. The 4300 Sovran also integrates the Volvo IPS Joystick control that puts unmatched low-speed maneuverability at your fingertips. With a single, subtle movement of the IPS Joystick, you command the IPS propulsion units to respond in any direction. This gives you the power to maintain control of your 4300 during tight-quarter docking, coming about, reversing or even going straight sideways ? all without the need for bow thrusters. Most importantly, because IPS takes up 25% less area in the 4300 Sovran, the design team was able to employ the newly available space as a full second stateroom with head. Design keys such as vessel sinks and shower partitions, an optional washer / dryer, a full-size refrigerator / freezer, even a spice rack and voluminous storage are but a few of the new options you will find. And the cockpit seating is both inviting and comfortable ? a perfect environment for the cruising lover. Engines Twin Volvo 500IPS engines only have 211 hours and are mounted in the cleanest engine room that you have seen! Incredible performance and fuel economy are provided via the joystick controlled IPS drives. Accommodations Step into the salon and you are greeted by the teak and holly sole. Immaculate, well appointed salon, provides plenty of comfortable seating for friends and family. The VIP stateroom is afte and features twin berths, easily converted to a full size berth, also has it's own head and shower. The master is forward, featuring a centerline berth with lots of storage on both sides, and Flatscreen mounted on port side. Huge master head with large seperate enclosed shower. Galley Galley is located to port and features: Solid Surface countertops Cabinet storage Under Counter storage Dometic Refrigerator Freezer Stainless steel 2 basin sink Kenyon 2 burner electric stove Smart Grill2 Convection oven Additional Information Additional Equipment includes: Forward deck sunpad Custom tinted EZ2CY drop curtain in cockpit 12000BTU cockpit AC/Heat TwinRaymarine E120's Raymarine Satellite TV Bowthruster Macerator w/Y valve 50 amp Glendenning Cablemaster 11.5 KW Onan genset w/only 175 hours Immaculate engine room
Boat Loans By Excel Credit.
More...
