Go Back   Forums Forums - Off Topic Forum FUN > Agriculture & DIY Forums > Tractor Forum
Tractor Forum Buying, Pricing and General Tractor talk
Reply
Thread Tools Display Modes
  #1
Old 03-22-2014, 02:14 PM
BigAl's Avatar
BigAl BigAl is offline
Platinum Member
BigAl will become famous soon enough
Default Spider cracking rear wheels
Ever had the center disk start cracking across at the wheel studs on your rear wheels ?? My Kioti started doing this a few years ago . Now its so bad I finally purchased new center disk at $275 a piece . Wheels have never been loose .
I am trying to figure out what caused it . I think it is a weight problem off the 3 pt hitch . I have a huge 6' blower and a removable backhoe that weighs quite a bit . The tires are loaded .
In checking other tractor forums I have not seen this as a recurring problem .
__________________
Big Al
2B1ASK1
See my Kristi Video here : Kristi KT3 - YouTube
Disclaimer: Read with caution !!
Poster may be Bad Speller at times .
  #2
Old 03-22-2014, 02:57 PM
Snowtrac Nome's Avatar
Default Re: Spider cracking rear wheels
I've seen Rockwell 22.5 stud plot on a 10 hole budd wheels do this I also had a steel wheel on the snot trac do it that is why I went back to the composite
__________________
Don
1962 st-4
KL2ZF
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
removing rear wheels utahwilson Snowcat Repairs, Parts & Problems Forum 22 03-24-2014 12:28 AM
Found some spider cracking on my rear wheels! BigAl Tractor Forum 14 11-18-2012 10:04 PM
Ground Shifting and Cracking, Water Coming in During The Quake pirate_girl Open Forum 2 03-13-2011 04:07 PM
Cracking the Scratch Lottery Code jim slagle Junkman's Corner 3 02-04-2011 11:47 PM
