I need some help . I purchased a Kracher 3000 PSI gas pressure washer at Costco about 6 -7 years years ago , It has worked well for pressure washing the house before I reoil it . Now it has developed this little problem of not wanting to build pressure when I pull the trigger . I can get it to work if I take off the tip but getting that back on the quick connect is dangerous . The local rental company mechanic said to junk it and buy a new pump . You guys have any ideals before i spent the bucks for a new pump ? The Honda 6.0 HP Motor works fine . I really like this unit but have been told the Kracher is junk ??? Is there a replacement pump that is better ??
