All terrain off road bandsaw
Mith
The Eccentric Englishman
Saves taking the work to the saw, take the saw to the work.
Jim is that a metal cutting bandsaw? Or is it a wood cutting unit used to make boards?
Do you have an inverter on the tractor to power it? Generator? Etc?
Mith
Bob, its a metal cutting but we also use it for cutting wood, makes a real fine cut on woods like mahogany.
I only use it either in the shed or garage, just it has to be stored in the garage for the dry, so I can tow it to the shed when need be. Though we do have a generator anyway.
But no, its not for boards, its like a mitre saw. Cutting skirting board with it is a dream, real easy to get all sorts of angles.
Doc, is that a good thing? :yum:
Thanks
