Re: Reconstituted Original Tractor Forum!!
BoneheadNW said:
Bob-
A quick question: My son is going to be 4 in another month. Trains are his second love after fire trucks. Do you think he is too young for a train set? Do you have any recommendations?
Bonehead
That really depends. Durwood certainly has one, very good idea, and that is just get a battery operated unit. If your son is going to play with it in an UNSUPERVISED fashion, then it is a very good option.
Playmobil makes some very nice stuff, it is plastic, sturdy, and my daughter at age 11 still plays with her Playmobil toys. Their trains are roughly G scale size so they are big enough to carry other toys around the track. A very nice thing about the Playmobil toys is that your son can easily transition from 'toy' trains to serious 'toy' trains and use the same track because the same track my Marklin Maxi trains use is the same used by the Playmobil, and that is also the same size as the LGB and other brands of G scale trains use.
My daughter, at age 4, was playing with Marklin MAXI series trains. They are a bit pricy, and they are metal so they can be bent. But the tops of the cars come off and she was able to drive her stuffed animials and Barbie dolls around the track. She and I played together with them and she learned how to treat them pretty early on. She rarely played with them by herself. I found I could trust her with them because she learned. I also found that she could not play with them with her friends because they didn't understand. So we ended up with some cheaper stuff and then the good stuff. The good stuff came out when she & I played.
MY QUESTION TO YOU is do you want a toy for your son, or do you want a toy for YOU & YOUR SON so you can bond together in another way?
