Go Back   Forums Forums - Off Topic Forum FUN > Vehicles > Military Vehicles Forum
Military Vehicles Forum Anything and everything about military vehicles. Restorations & more. Pictures encouraged.
Reply
Thread Tools Display Modes
  #1
Old 07-22-2015, 11:36 AM
SBT22OPERATOR SBT22OPERATOR is offline
Junior Member
SBT22OPERATOR is on a distinguished road
Default Military Vehicle Surplus Parts HELP!!!
Hi Everyone!
So I'm new to the forum, and this is my first post. Hopefully someone in the community will be able to point me in the right direction...
A close family member recently passed away and my cousin and I are left with a huge pile of surplus new old stock military vehicle and generator parts. I have no idea what to do with them, and my cousin is ready to just haul the entire lot to the scrapyard.
I'm sure somebody could put some or all of these parts to good use, and I'm positive that they are worth way more than scrap value.
I tried to attach the parts manifest as a spreadsheet file because it's easier to read than cutting and pasting, but apparently open office files are not acceptable attachments in the forum. Maybe an admin can fix that?
What follows is a cut and paste of that spreadsheet. I can send the actual file to anyone who is interested.
Any suggestions or leads on who I should talk to would be greatly appreciated. Thanks in advance folks!
- Drew
NSN ITEM PACK SIZE TOTAL PACKS EXTD. COUNT
2530009775741 KIT, AIRWAY REPAIR RELAY VALVE 1 EA 4 4
2815001955897 ROCKER ARM 1 EA 17 17
2805000798666 SUPPORT, ENGINE MOUNT 1 EA 3 3
2530008541724 CYLINDER ASSEMBLY 1 EA 6 6
2910012534648 HOUSING 1 EA 3 3
2815012532021 PISTON 1 EA 3 3
2910012533456 HOUSING 1 EA 3 3
2920008823401 STARTER, 24 VOLT 1 EA 1 1
UNKNOWN MISC. PISTONS 1 EA 5 5
2520010681109 BALL 1 EA 54 54
2805000761363 TAPPET 6 EA 17 102
2805003943696 JACKET ASSEMBLY 1 EA 4 4
UNKNOWN LESTEK INC. ALTERNATOR MODEL #9135G 1 EA 1 1
2530008449697 HUB 1 EA 5 5
2815012477899 LINER, STANDARD 1 EA 3 3
2520007409090 BOX CONTROL, DEUCE AND DUMP 1 EA 1 1
2530005618643 SPACER, WHEEL 1 EA 5 5
2815012833218 MANIFOLD, EXHAUST 1 EA 2 2
2815002781537 RING PISTON 1 EA 7 7
UNKNOWN MUFFLER 1 EA 1 1
UNKNOWN BRAKE MASTER CYLINDER 1 EA 1 1
2930012663463 WATER OUTLET, ENGINE 1 EA 3 3
2815012531985 VALVE 1 EA 5 5
2815012530427 VALVE 1 EA 13 13
4940007363570 AIR CLEANER 1 EA 8 8
2930004516070 IMPELLER, FAN, AXIAL 1 EA 1 1
UNKNOWN EXHAUST, Y PIPE 1 EA 1 1
2920011012708 REGULATOR, ENGINE GENERATOR 1 EA 20 20
2530013648821 WHEEL CYLINDER 1 EA 19 19
2530000212366 PARTS KIT, VALVE ASSY, EMERGENCY RELAY 1 EA 1 1
2910011811955 DRIVE ASSEMBLY 1 EA 4 4
2540012018902 LEVER 1 EA 22 22
2910005888440 TUBE 1 EA 4 4
UNKNOWN MISC. PARTS 1 EA 4 4
2815002293623 STABILIZER 30 EA + 25 EA + 34 EA 10 + 2 + 1 384
2920011600510 RING ASSEMBLY 1 EA 1 1
2530004416517 CYLINDER ASSEMBLY 1 EA 15 15
2815011024771 MANIFOLD, EXHAUST 1 EA 1 1
2910001917157 CABLE ASSEMBLY 1 EA 1 1
4820012044511 SEAT VALVE 1 EA 29 29
2990012105814 PUSH ROD 1 EA 51 51
2990012915881 PIPE, EXHAUST 1 EA 3 3
9340006313296 WINDOW 1 EA 6 6
2815012833218 MANIFOLD, EXHAUST 1 EA 1 1
2815011024771 MANIFOLD, EXHAUST 1 EA 4 4
2520001849383 PRESSURE PLATE 1 EA 5 5
2540004976271 HEATER CORE 1 EA 2 2
2990008586015 EXTENSION, EXHAUST 1 EA 1 1
2530010445433 WHEEL, SOLID, NON METALLIC 1 EA 7 7
2805006245339 OIL PUMP 1 EA 2 2
UNKNOWN MISC. MANIFOLDS 1 EA 3 3
2520010523558 SUPPORT, ASSEMBLY 1 EA 1 1
2990011010043 ACTUATOR, GOVERNOR 1 EA 1 1
2990012841078 HOUSING 1 EA 2 2
2815011894776 SLEEVE, CYLINDER 1 EA 6 6
2910006982936 TIP KIT 1 EA 14 14
2910006982936 PARTS KIT 1 EA 10 10
2530012514428 PARTS KIT, TREDLE VALVE 1 EA 3 3
2920002935189 SPARK PLUGS 10 EA 14 AND 1 INDV 141
2815012533299 INSERT 1 EA 3 3
2530000301408 DUST SHEILD 1 EA 8 8
2520007370923 CONVERTER 1 EA 1 1
UNKNOWN MISC. BRAKE DRUMS 1 EA 4 4
192077376689??? FORT WAYNE PARTS EQUIPMENT STEERING BOX? 1 EA 1 1
2910004211541 SHAFT ASSEMBLY 1 EA 17 17
2530001928931 TIE ROD 1 EA 3 3
2520009926824 PARTS KIT, UNIVERSAL JOINT 1 EA 15 15
2815000972116 ROD 1 EA 2 2
2910012831997 HOUSING 1 EA 2 2
2805010064625 PIN ASSEMBLY 1 EA 24 24
2815010731436 PISTON, INTERNAL COMBUSTION 1 EA 3 3
UNKNOWN MISC. BEARING 1 EA 1 1
5360009246118 SPRING 5 EA 43 215
UNKNOWN MISC. PERKINS ENGINE PARTS 1 EA 1 1
2530009672057 TIE ROD END, STEERING 1 EA 2 2
578 TOTAL PACKS 1332 TOTAL PIECES
  #2
Old 06-30-2016, 12:14 PM
Kawgomoo Kawgomoo is offline
Junior Member
Kawgomoo is on a distinguished road
Default Re: Military Vehicle Surplus Parts HELP!!!
Just curious, did you ever figure this out? Did you scrap all this stuff?
My goodness, i can't believe no one would offer to buy it! I would have!
602 628 5489
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
WTB Military ST4 Ignition parts tortoise7 Snowcat Classifieds (For Sale / Wanted) Forum 0 03-14-2014 02:54 PM
What's your favorite military vehicle? bczoom Military Vehicles Forum 57 02-06-2012 08:16 AM
evinrude skeeter snow vehicle parts for free kermit2 ATV's / RTV's / UTV's / Side-by-Side's Forum 1 02-13-2009 03:46 PM
military parts question / BV 202E MK II tortoise7 Snowcat Restoration & Modification Projects Forum 2 10-19-2008 12:36 PM
1975 military st4, source needed for 24volt parts tortoise7 Snowcat Repairs, Parts & Problems Forum 2 11-15-2006 11:11 PM
