Yes but do you have one of these ???
. Its the dash placard that came on the KT3 . I can reproduce one for you , because I am a
wonderful guy who can make a printed exact copy on heavy paper for free to anybody that needs one !!!
THE KRISTI CO.
P. O. BOX 15515 . . . DENVER 15, COLORADO
KRISTI Model_____
U.S. Patents 2,434,693 - 2,700,427 - 2,905,479 - 2,967,578 - 3,019,061
Canada Patents 442,693 - 497,519
Serial No. _____________ Other Patents Pending
______________________________________________________________________________
CHECK LIST
GAS - Regular in VW-Premium in Porsche and Corvair TRANSMISSION-HD SAE-90
ENGINE - Oil HD-HD SAE-30 DIFFERENTIAL-HD SAE-90
32* minus SAE-20 TRACK- Tension-Cleats-Guides
HYDRAULIC-SAE-10 (Non Detergent) Tires - 25psi
BATTERY LIGHTS
OPERATING INSTRUCTIONS
Start (cold) WARM-UP (3-5 Minutes) PUMP UP SYSTEM
Depress clutch Lights out* Open both pump up valves and tilt
Pump throttle Choke as necessary to left or right until system starts to
Choke full Open Air inlet by-pass. Next close pump up valves
Turn key and press starter button Open Air outlet as necessary and return body to neutral position .
CRUISE-Engine RPM (VW2500-3300,Porsche 2700-3500,Corvair2600-4000)
Do not lug down.
GEARS-KT2A-KT3: Use red stick neutral only. Normal start 2nd or 3rd gear-low. Use Low-High shift to split gears if necessary .
KT4: has 4-speed transmission
TURN-Levers give 12’ minimum radius. “Caution” Turn gently over obstacles, soft ground, steep side-hills.
Brakes- Pull both levers at once. Park in 1st gear low.
SKI-ACTION HYDRAULIC CONTROL- Tilt left and right to level body. Return control to center when desired tilt is obtained
“Caution” Anticipate tilt necessary and adjust control on approach. KT4A- Refer to operating manual. * If red light remains on stop engine- check oil level- re-start in 3 minutes
