Go Back   Forums Forums - Off Topic Forum FUN > Snow Trac ST4, Kristi, Thiokol/LMC, Tucker, Bombardier & Other Snowcat Discussions > Snowcat Restoration & Modification Projects Forum
Snowcat Restoration & Modification Projects Forum Major Restorations, Upgrades, and Non-Stock Snowcat Modifications
Reply
Thread Tools Display Modes
  #81
Old 03-23-2020, 10:05 PM
KickerM's Avatar
KickerM KickerM is online now
KickerM is on a distinguished road
Default Re: Converting to a 5 man cab!
Got the Cradle sandblasted, Now its ready to be primed and painted today! Its amazing that this 30# formed steel holds the entire powerpack....
__________________
Cowboy Logic: Bad decisions usually make good stories!
1964 Thikol 1202 CrewCab "Sold"
1972 Bombardier SV250S
1987 LMC 3700 CF
1998 M923A2 5-Ton
The Following 6 Users Say Thank You to KickerM For This Useful Post:
1boringguy (03-23-2020), BearGap (03-24-2020), jim slagle  (03-24-2020), PJL (03-23-2020), Pontoon Princess (03-23-2020), Snowy Rivers (03-24-2020)
  #82
Old 03-24-2020, 08:02 AM
Snowy Rivers Snowy Rivers is offline
Snowy Rivers is on a distinguished road
Looking good.
The weight is hanging nearly directly straight down on the side bars....you could lift the entire machine with those two side pieces.
Does the cradle sit on the bottom of the tub ????
I assume the cradle bolts into the tub at several points ????
Plenty strong hold the little 6 cyl and tranny....
The Following User Says Thank You to Snowy Rivers For This Useful Post:
  #83
Old 03-24-2020, 04:41 PM
KickerM's Avatar
The cradle is suspended above the bottom of the tub, and you are correct in that it sits along the lip of the tub edge, but it is only held in by 4 bolts into 16ga sheet steel, mine was rusted so the entire deck of the tub was torched off and I welded 3x3x3/16 angle iron down the top edge from fore to aft, so now the cradle is well positioned to hold anything....original plan was for a 6BT!
__________________
1987 LMC 3700 CF
1998 M923A2 5-Ton
The Following User Says Thank You to KickerM For This Useful Post:
  #84
Old 03-24-2020, 04:54 PM
Yeah...you got it plenty beefy now ...
  #85
Old 03-25-2020, 10:36 PM
KickerM's Avatar
Default Converting to a 5 man cab!
Getting some good time to work on cat in between checking the cows. Welded all the cracks in the tub, made up skid plates (I even welded directions on the skid plate, so when your upside down in the snow you know which way is forward!) then drilled holes and fitted cage nuts in the tub for said skid plates, then Wire-wheeled the tub, stripped, primed and painted! Now to set the cradle and drill the holes thru the angle iron
__________________
1987 LMC 3700 CF
1998 M923A2 5-Ton
The Following 5 Users Say Thank You to KickerM For This Useful Post:
BearGap (03-26-2020), DAVENET (03-26-2020), PJL (03-25-2020), Pontoon Princess (03-26-2020), Snowy Rivers (03-26-2020)
  #86
Old 03-29-2020, 02:39 PM
KickerM's Avatar
After 2 years and 3 months the power pack is back where it belongs! Now to start the process of fine tuning all my measurements and make sure all my paper ideas fit into the actual machine!
Measuring up the Transmission cooler lines to replace with single piece hydraulic hose lines, the old ones transitioned between steel and rubber with adapters and pipe clamps I cant count how many times.... KISS!!!!
__________________
1987 LMC 3700 CF
1998 M923A2 5-Ton
The Following 3 Users Say Thank You to KickerM For This Useful Post:
PJL (03-29-2020), Pontoon Princess (03-29-2020), Snowy Rivers (03-29-2020)
  #87
Old 03-29-2020, 02:51 PM
Looks great.
Having a bullet proof oil cooler set up is nice.
All the clamps and splices is definitely not a good idea.
Just don't need a leak somewhere....
KickerM (03-29-2020)
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
converting to gooseneck JimVT Trailers & Tow Vehicles Forum 6 05-16-2015 12:57 PM
Converting to Islam ? nixon Religious Debate Forum 7 11-16-2014 09:10 PM
converting from 24v-12v John Lumley Snowcat Repairs, Parts & Problems Forum 4 01-12-2010 05:23 PM
Converting VHS to DVD jpr62902 Computers, Cell Phones & Electronics Forum 16 01-15-2007 02:53 PM
Converting .wmv to .avi files? Melensdad Computers, Cell Phones & Electronics Forum 4 04-08-2006 12:00 AM
