1955tucker443
I've never figured out what the proper fluid level is in the Tucker tranfer case on my 1955 model 443. The fill hole is on the top of the case(accessed under the seat) and there are 2 small (1/4 inch) "inspection" plugs on the front of the case. One is just above the output yokes and the other just below. If I fill the case to the upper plug I get alot of leakage out of the yokes (even when not running) - possibly bad seals? If I fill it to the level of the bottom plug I get little or no leakage even while running. Does anyone know what the correct level is?
Thanks, Tom
Thanks, Tom
