rear drive differential
Hello,
Can anyone identify the differential in the picture ? Its on a homemade snowcat and is a two speed differential. The lever in on the right side shifts it. I broke something internal and wanted to identify it to see if there are parts available. thanks
PJL
This is a pic of a M29 Weasel differential. Looks like what you have.
redsqwrl
The chassis of that cat appears to be an A model spryte,
Could be a lite foot proto-type
redsqwrl
only two things make me suggest that it is an A model.
A) the structure that would have been holding the original diff is not there a B/C model hangs from the tunnel, A models hang in an underslung manner and they rely on the drop boxes for support.
B) the Sprockets that drive the track look very much the same as the larger A model. smaller bolt pattern.
I am no expert, but to have those parts and gousers would be odd to have it been modified from any other model? are you axles coil springs?
Yes, actually I have been in a selling mood recently,(doesn't happen often) There is a bidding situation on the 58' ST4, a couple of gentlemen are bantering with a indecisive seller......
redsqwrl
A model sprytes are great machines, Of all the cat chassis's I play with I really enjoy how nimble and light the A models are.
The banter is fun and centered around the 58' machine. it is currently subaru powered, I have the original engine also.
Thebartman
HI. I'm in Helena. We should get a group together. Maybe, someday a snowcat jamboree on our home turf?
After visiting Beartooth yesterday and looking at his amazing collection of snowcats, I was motivated to lay out on the frozen ground and tear into the rear differential on the snowcat. Here is what cat4.jpgI found in the left side drop box. That's a triple roller chain broken and wadded up in there.
Cidertom
Chionophile
Any ideas of where we go for a cat gathering ?
McCall Idahoe is prob the closest for you. see the mccallin all cats entry in adventures http://www.forumsforums.com/3_9/showthread.php?t=77286
even if you can't get the cat there, go yourself, it is a great networking opportunity and the ability to pick brains of those who have already been down the roads you are about to travel. or to discuss those things we all hold dearly: quality of snow, public lands, hot booze drinks...
Cidertom
Chionophile
Oh, and the highway department wants to discuss your source of aluminum skin for your cat...
Snowy Rivers
Montana
I am curious about the chain boxes used on your cat ????
I have a very good chance of securing a WEASEL rear axle for my project and knowing what your boxes came from (Or home made) would be sweet.
Thanks
Completely homemade ! I was totally amazed when I disassembled this machine at the craftsmanship, countless hours the builder put into this. I talked to the builders son last night and he told me his dad build that that cat with an arc welder using E 6011 rod completely under the Big Montana Sky. (no shop). I can take some pictures of it as I am about put it back together thanks to U.S. Roller chain and sprocket company. (very nice people) The builder suspended the weasel differential by sliding a 1/2 piece of flatiron between the differential and axle tube, axle tube bolts hold the diff in place. The drive axle has a pillow block bearing bolted to the cover for the drop box. You can also see where he welded some side gear that fit his axle splines into the center of the sprocket. His son told me that the cat is powered by a 287 Rambler V-8 backed with an automatic transmission. A low budget marvel to say the least.
Cletis
Montana B, I just spent a few days around Jackson, Wy. The powder was crazy fun. Driving over Togwotee pass out of Dubois was killing me not to stop and play. Powder was deep! I plan on several trips to Togwotee pass next yr for sure. Not sure about this yr but if you Montanans had any good, deep powder areas up there to play in for next yr, I'd be in for coming up from Wy.
Cletis
