Need Help cutting 8"x8"
79bombi
Site Supporter
I am in the process of building a timber frame woodshed. I'll post that later. My circular saw has a blade that is not capable of cutting thru a 8"x8". Any ideas how to cut it and get a straight cut? My local rental place does not rent a big circular saw that timber framers use.
79Bombi
Jim_S
how good are you with a chain saw?
Or, use your circular saw and a framing square to line things up. Cut all four sides and then use a hand saw for the middle.
Spiffy1
Huh?
The former was my first thought too; I've had pretty good results even on railroad ties. I'm not sure if I'm that bad with a framing square or just always find twisted and warped wood, but while only having tried it a couple times, I've never had the second method to come out with less than a blade width of error.
Now if you need perfection, I've never seen it done, but a little carpentry with your circular saw & a hole through your chainsaw bar might make for a neat "chainsaw miterbox" ! For slightly less precision a couple upright 2X6 guides on whatever base might do the same for you without drilling your bar - if you don't get off and chew them up on the first 8X8!
XeVfTEUtaAqJHTqq
Master of Distraction
I've done both of these. You can get a pretty good cut with a Chainsaw if you practice a little.
jwstewar
What about a recip saw? I've gotten pretty goods cuts before with one and a 12" blade. Just draw a line completely around so that you can see where you are supposed to be.
Av8r3400
Gone Flyin'
My FIL has a timber saw, so I didn't need one on the Log House.
My neighbor (Building a Timber Frame House) just bought one, then plans on reselling it on Scam-Bay when he was done with it. According to him, this is very common with the timber frame builders. EBay
Spiffy1
Huh?
Waaayyy off topic, but I had to do a double [more like triple] take on this "Beam Saw" in your ebay search. I'd never seen one; not a bad likeness of the Poulan. No, I'm not bidding on it. Carry on.....
XeVfTEUtaAqJHTqq
Might just be the operator but I've had a lot of bad cuts from reciprocating saws. If you do go with a reciprocating saw get a good stiff blade and watch for the bending. :doh:
Jim_S
That's the problem with long blades and thick material on a recip saw :sad:
79bombi
Site Supporter
This was one of my thoughts I just wanted to make sure I wasn't missing the obvious. I figure I can use the first cut to start the second cut, etc... It is pressure treated oak also.
79Bombi
Spiffy1
Huh?
79Bombi
You might want to try the framing square to mark it out. Again, maybe it's me or the lumber I've used, but for me while bad enough if it's marked: after rotating something 3 times [using the end for the next start], I'm lucky to come close to hitting the 1st starting point. :doh:
Pressure treated oak?! :thumb: That can't be cheap!
k-dog
I would do a combo of circular saw and recip saw. Cut as deep as you can with circular saw and finish with recip saw or do all the sides with circular saw and then do middle with recip saw. I've never had good luck just using recip saw. It seems the longer blades dance all over the place and bend pretty easy, even the better name blades.
Erik
SelfBane
Site Supporter
actually, my gransberg mini-mill & my beam machine do a good job of cross cutting big stuff, too. (different chainsaw attachments, good for ripping, but require a straight 2X to be nailed to the log as a guide)
cabinboy
I have a prazi beam cutter and it works great for cutting log or beams. the one I have is mounted on a dywalt skill saw . it has been used for three cabin and is being used by my a friend to cut beams on his cabin. This saw has worked great. You could even make dovetailed corners for your building and they would look great. :thumb::thumb:
Dargo
Like a bad penny...
The old fashion way, hand saw it.
I was going to suggest that but while using an old miter box to keep the cut straight. I have an old miter box from my grandfather they used when building his house. All it does is keep your handsaw straight.
spencerhenry
if you are trying to make a cut for the end of a beam that is visible, a portable band saw works excellent. if you dont have the dough or cant rent one, a skil saw from all four sides and then a sawzall, and then a grinder with a sanding disc to clean it up.
if you are making a cut for a joint, like the top of a post, or a splice, it is a combination of tools. say you are cutting an 8x8 for a post. draw square lines around all four sides, hopefully they all line up when done, if not try again. using a skil saw cut all four sides. then with a chainsaw cut about a half inch longer than needed and cut the piece off. now take the chainsaw in from each side at a slight angle, removing the half inch long part, but do not get the chain into the area already cut. you will be leaving the 2 inches or so around the outside as is and cutting the center of the piece a little bit lower. you can also do the dishing out with a grinder with a sanding disc. cutting the center of the post below the skil saw cuts allows for easy fitting of the pieces. there is still plenty of bearing, but no high spot in the center to open up your joint. i have done a fair amount of structural and architectural timbers and that has always worked well for me.
lowell
There is an attachment that just clamps onto the bar then you use a 2x4 as a guide but you need to get a different chain with a I beleive a 15 deg. angle on the cutters , if you try to use a reg. chain it will load up on you as when trying to rip with a cross cut . jmo
