Had to use a hack saw to get the adjusters off the frame (just enough room to get the blade in between the bracket on the frame and the adjuster assembly) . Then it was 13 tons pressure on the press and lots of heat to get the pins out. In case anyone else has to replace these pins they are 20 mm in daimeter and not 3/4 of an inch as I thought at first glance. Grease nipples were then installed to prevent the problem from reoccuring. Once I get more familiar with the forum usage I will add pictures as I slowly rebuild the machine.
Brian
1977 ST4
1972 SW 48 Bombardier
1988 BR 100 Bombardier
Brian
1977 ST4
