The HVAC set up in my house is not quite good enough. During weather extremes the master bedroom is either too hot (summer) or too cold (winter). The problem seems to be that the duct runs to the master bedroom end of the house are simply too long. Too far from the furnace fan and so we don't get enough airflow into the bedroom/bathroom.
The correct solution might be to add a second HVAC unit to the house. The problem with doing that is finding the space to install it that would shorten the duct runs.
Sooooo, as a last ditch effort I'm planning to install a couple automatic in-line duct booster fans. Of course nobody has them in stock placed 2 on order and should have them next week. That's actually good, I don't relish the idea of crawling around my attic when it's 105 outside, must be 40 degrees warmer in the attic. Hopefully the install will be pretty quick and hopefully it will cool off about 20 degrees for the morning I do the install.
