BETTER LATE, THEN NEVER.
or
"REAL HOME IMPROVEMENT".
Tommas Edison is remembered as having warned us, and I believe he is quoted as having said, "You would be a fool to use A/C voltage rather then D/C voltage. But his nation did not heed his words of wisdom.
If Tommas Edison, the man who seems to have "opened the door" to the uses of electric current, was a child of God, (which is now evident from his effect on mankind), then at that time this nation turned from God, and began to lead others away, through its' example. The many blessings that are afforded mankind, through the use of electricity, shows that the hand of God was guiding Edison, and mankind through him, into the "Age of Electricity"
The warning given to others, concerning the use of A/C voltage, was given by the one who may have had the best understanding of electricity. This would be evident from the way he used such knowledge through-out his life.
Now today, information being gathered from studies, indicates that the use of A/C voltage may have been a wrong move for mankind. And obvious to anyone with a basic understanding of electricity, is the fact that the magnetic field produced by A/C voltage is more in contrast with the earth's field then D/C. More like the earth's, the magnetic field produced by D/C voltage is constant.
But this may not be worth noting, unless there are life forms known to use the earth's magnetic field, such as magnetic bacteria. The small magnetic particles found with-in bacteria are noted as causing it to be effected by magnetic fields. These particles being found in man, should be viewed in that same light.
The effect of bringing this issue to the forefront, as a "news topic", and having it held there long enough to educate people to the fact that they are being effected, health-wise, by magnetic fields would be deemed necessary by anyone who becomes aware of these facts, and has the best interests of everyone in mind.
John 12:46 I am come a light into the world, that whosoever believeth on me should not abide in darkness.
