Posted by: gmweiss
Description: General Description Boat Name Like 2 Fish Dimensions LOA: 36 ft 8 in Beam: 10 ft 0 in Maximum Draft: 1 ft 8 in Displacement: 12000 lbs Deadrise: 24 ° at Transom Engines Engine Brand: Yamaha Engine(s) Total Power: 750 HP Engine Model: F250 Engine Type: Outboard 4S Year Built: 2004 Tanks Fuel Tanks: 1 (510 Gallons) Construction Cored reinforced hull bottom with molded in stringers, stiffeners, and partial transverse bulkheading.Topsides are cored fiberglass. Deck is cored molded fiberglass, joined to hull, and chemically and mechanically bonded (through bolted). Electrical 12vDC and 120vAC with four group Optima 34M AGM batteries. Engine start/ ships service batteries are located in leaning post rigging compartment in heavy duty battery trays, secured with brackets. Stranded thermoplastic shielded wiring to selector/parallel switches located same compartment. Stranded thermoplastic shielded wiring to circuit breaker panel and Moritz Digital Control Processor located inside center console, starboard side,and to micro switch control panel at helm. All DC equipment is adequately circuited and breakered. Battery charger for battery maintenance- Promariner 15 amp 120vAC with a battery charger inlet on leaning post, port side. Tinned multistrand wire to battery charger twenty four inches away. Electronics & Navigation Raymarine E120 Garmin 740S Raymarine 215 DSC VHF (2) Dytek ST500 Temp Ritchie Compass Audiovox Sirrius Satellite Radio & Remote Sony Xpod Rockford Fosgate Amp P80004 Kicker ZX750.1 Raymarine DSM300 Raymarine Seatalk Simrad Autopilot AP26 JL Audio Speakers Isotherm 38 Rodholders Telescopic Outriggers Additional Equipment AmeriTrail aluminum triple axle float on type trailer, with surge disk brakes on front two axles, and spare tire/ hub assembly. Kiekhaefer Trim tabs Marine toilet under console 12Vdc outlets port and starboard at transom Fresh water wash down Salt water wash down Port and starboard under gunwale lighting Gunwale, t top and transom mount flush rodholders (38) Sunbrella weather cover Coffin box with matching seat cushion and electric hatch lift For and aft spreader lights at T top Fish box pump out Grand Slam outrigger bases at T top Layout Center console open fisherman type with chain locker in forepeak, accessible from ring deck hatch (gunwale). Single level weather deck with storage under. Center console with port side door opening, and portable toilet inside. Aft of center console is leaning post/ bait well with aft seating, above with is a T top with upper steering station with engine controls and leaning post/seat. Transom is closed with transom door, starboard side out to built in swim platform. Safety/Regulatory Equipment: Navigation lights (8) Adult type II life preservers located under forward under gunwale port and starboard storage shelves behind snap on retailing nets B1 fire extinguisher loose inside console Pull out boarding ladder at transom, stbd side Manual signal horn Orion Alert/ Locate visual distress signal kit- expired First Aid kit Oil Discharge placard mounted inside console Trash Disposal placard mounted inside console Rulemate 1500 duel mode bilge pump at aft bilge Rulemate 2000 duel mode bilge pump at aft bilge Type IV throwable buoyant cushion under center console Ground Tackle At bow chain locker – Galvanized 15 lb. lightweight type anchor with an adequate length of 3/8” galvanized chain, and an adequate length of ½” twisted three stranded nylon rode. Underwater Sections & Running Gear Hull has raked stem, hard chine “V” bottom, with lift strakes forward of a ventilation step, transom stern with a built in outboard bracket and swim platforms. Hydraulic trim tabs were in place. Running gear consists of triple counter rotating gasoline outboards with four blad props. Engines Triple F250 Yamaha Engines. 4 Blade props Disclaimer The Company offers the details of this vessel in good faith but cannot guarantee or warrant the accuracy of this information nor warrant the condition of the vessel. A buyer should instruct his agents, or his surveyors, to investigate such details as the buyer desires validated. This vessel is offered subject to prior sale, price change, or withdrawal without notice.
Boat Loans By Excel Credit.
More...
More...
