archives
olympicorange
…. shades...
olympicorange
...... so getting back to the ''diesel puller'' topic,... made some progress ystrdy. did some horse trading,... traded a farm attachment for an ''engineless'' horse. from PA. originally. with a 7.4L. going to drop the 6.2L into it. 460 mlle roundtrip ..... '87 K30 Scottsdale 3+3 ..... with TH400 & NP205 Cast/gear to gear.....
PJL
The little 6.2 Detroit? Not a powerhouse but it's easy on fuel. That's a good trade. Truck looks nice.
olympicorange
...... Lol ,.... strawberries & pistachios clash,.... :smile: silvers good,.... im thinking.... yes, no big power, on the 6.2L . Better torque & fuel economy than the burb,... and not so much Heat under the hood. nothing a turbo wouldn't spruce up,.... hmmmmm.
PJL
Customer: My truck won't start, I think the engine has a bad miss.
Mechanic: Shakes his head and walks away
olympicorange
.... :thumbup:...... well, to any gearhead.... same scenario as a snocat, I guess.... it certainly deters the masses , in such a circumstance.... lowers the price,.. ( except tuckers..lol),... and opens up the possibilities,.... like,...'' well it needed something to update/modify/ improve, etc... because it was missing something....'' or....''well, half the work has already been started or done...'' . ( in all reality; I like to revive old iron... )......
olympicorange
...... started a little ''6.2 project'' time.........
olympicorange
....... algae control on the Lake has been completed,... all equipment overhauled.... back to work,....
DAVENET
Looks like you could use a .223 in the cab to control something else . . .! With all of the rain the other night I figured your lake might just refill!
olympicorange
….. yes,... critter control. momma coyote has 4 pups,...ones a runt. not a worry in the world around the haying process,.... but as they get older, going to be an issue..... unfortunately . the turkey population has been cleaned out,....
olympicorange
……… frt. suspension rebuilt/upgraded....bottom end of 6.2L freshened...
olympicorange
……….. been hauling a lot of different items,... had to add more ''D'' rings & grab hooks...
olympicorange
……… LOL.,,, well... case in point ,... todays save from the scrap pile,... ( just gotta figure out how to mount these onto the pontoon digger)...
olympicorange
,...… SO ,... any Duramax people out there experiencing a ''cavitation '' issue with the fuel filter on top of the engine?? … my Kodiak started a few weeks ago with this issue. it would just ''die'' cruising along, with no indication. the error code would be a fuel rail loss of pressure. each time the filter would be half empty, and air bound. prime it up & away I would go. ( but the only way to do that was to remove the filter & fill it up). the issue was getting the filter off, at 210 degrees , tucked under the cab, over the engine, dripping fuel all over, can't get your hands in there, etc. etc. highway traffic ''whizzing'' by …. a real dangerous headache, to say the least. spent the day tearing into the issue today. ( and the hand primer pump wasn't working properly , to make issues worse). so that was my target , starting point. problem is, you have to tear the whole top end apart , to get to it . and changing the filter really sucks on a Kodiak. ( I don't think the pickups are a whole lot nicer). what I found was ''something'' ...fiberish ?? ( looked like something you would pull out of your shower drain),... was stuck in the ''supply''...suction ...check valve . the ''delivery '' ..or outlet....check valve was fine. so upon removing the check valve to clean & flush, the idea of replacing the filter head assy., was reverted. the ''tricky'' maneuver on reinstalling the check valve is, getting the ''return'' spring back over the little ''legs'' or ''knubs'' of the check valve. now that will test your patience , & your eyes. so ,... I did what GM should have done from the ''get go'' ,... remotely mounted the fuel filter , to alleviate all that ,.. without the need of removing the inner fender. and you can get your hand onto the primer pump to operate,.. without burning yourself. ( beacause on a 90 degree day, with a smoldering engine,... you can sit beside the raod for along time , for it to cool down enough to ''handle'',.. or just get run into , or ''over''). and the primer pump now works properly. gotta love this mechanical stuff, ...especially if an ..''ECM'' ..is attached to it..... hope this helps someone out there,...
olympicorange
……… P.S.,... I omitted the cause of the ''cavitation'',... the O.E.M ''molded'' supply hose was compromised, ''damp'' ,...which was located behind the filter housing , attached to the engine fuel line. coincidentally , removing the filter & installing it , would reposition it enough to stop cavitating, but the ''intervals '' were getting shorter & shorter. the check valve repair was to get the hand primer pump working again, only …. so the moral of the story is that... rubber fails after a period of time....
olympicorange
………….. so,... knock on wood... three test drives & three transport / deliveries,...and 500 miles so far,.... hasn't skipped a beat. nice not to be stuck on the side of the hwy.,....every 20 miles,.. and back to algae control tonite...
olympicorange
assisted with winch install, for a local club. this terra 2000 replaces a prinoth,.... this compliments the other 1000 .....
  • Like
Reactions: PJL
olympicorange
mack has a bulldog,... and the girls brought back a noodle,.... well, at least she's the same size as the hood ornament,....
olympicorange
''OC '' Time,... at .....the TIM ONEILL rally/driving school ..... Team O'neill ,...
