I never go to into my downstairs garage . My kids use it for storing their crap that they are to lazy to haul off to their own homes . The overhead light quit working years ago and since I never go in there I could have cared less about fixing it . Figured I would fix it when I got to use it again .
So I go buy a new lite thinking the old ballast burned out because now I have decided that I will just rent the old place out until the economy turns around after I been dead for 30 years .
I installed the new light and hit the switch ..... zip, nada, nothing .....WTH ??? I go check my GFI's and breakers . they are ok . Then I decide to pull the switch cover plate off . Hey ! This is a 3 way switch ??? Then I remember that my kids piled a mattess up in the corner where the outside door is .I had forgot about that . Is there another 3 way switch over there ???
IT CANNOT BE THAT SIMPLE !!!! I knew what was wrong . That hidden 3 way was mis wired . Sure as shit the switch was flipped up and when I switched it down I was rewarded with light !!!! All I had to do was correctly wire the switch and it only took me 10 years to do it !!!
