Murph posted about clocks tonite. Here is a reminder to do a little more work while you are at it.
Check all your smoke detectors when you change your clocks.
1 - check and/or replace the batteries. In our area, we (FD) recommend replacing batteries at the spring and fall time changes. Batteries should last far longer than 6 months, but it is cheap insurance.
line power/110v detectors have test/check modes too; check them all
2 - Clean/dust the smoke detector as recommended by the manufacturer.
3 - Replace smoke detector as required. Most smoke detectors have between a 5 and 10 year effective lifetime.
4 - If you don't have smoke detectors, get some...
Check with your local fire department for regional or local requirements, or if you need help. They can also give recommendations for placement, and type of detector.
