Go Back   Forums Forums - Off Topic Forum FUN > Agriculture & DIY Forums > Tools & Tractor Implements Forum
Reply
Thread Tools Display Modes
  #1
Old 08-10-2017, 10:26 AM
joeboxer joeboxer is offline
Junior Member
joeboxer is on a distinguished road
Default track snowblowers
anyone have any input on track snow blower good bad?
tracks a problem? looking at ariens or a huskavarna
  #2
Old 08-10-2017, 04:14 PM
Snowtrac Nome's Avatar
Default Re: track snowblowers
I like Honda and their hydrostatic drive models the best any blower that is mtd based will have friction drive and must be stored in a garage or it wont work during the next use until it is thawed
__________________
Don
1962 st-4
KL2ZF
The Following 2 Users Say Thank You to Snowtrac Nome For This Useful Post:
300 H and H (08-11-2017), joeboxer (08-11-2017)
  #3
Old 08-11-2017, 08:08 AM
300 H and H's Avatar
300 H and H 300 H and H is online now
I have a MTD Troy Built. I keep in a heated shop, and get along well with the friction drives. But Don is correct, they are not anything like a hydro drive.
Much better than wheels, the tracks let you adjust how high you want to cut. On the high setting, I can skim over the grass in the yard for trails for our pets. And do so with only one hand on the machine...
__________________
Snow trac ST4 #267
The Following User Says Thank You to 300 H and H For This Useful Post:
  #4
Old 08-18-2017, 12:52 PM
jwstewar's Avatar
jwstewar jwstewar is offline
jwstewar is on a distinguished road
I bought Dad a tracked drive snowblower in the early 90s from MTD (before I knew what MTD stood for), he didn't use it but 2 or 3 times, but every time he did, the "Guts" would fall out from under it. He would put it back together and use Loctite only for it to do it again. When I passed I brought it home and put it back together again, I used Hi-Strength Loctite. I've used it a few times now and it is staying together this time. It works pretty well, I can clear the driveway 2x faster with that 28" width than I can with the 5' blade behind my tractor and it is clearer - just don't use it if it is windy, you'll be a snowman. I have yet to see it not be able to push it's way through something. I need to pull the carb off the Tecumseh engine and clean it as it is a bit rough running - but with the electric start on it, it always starts and runs - albeit rough.
__________________
Jim
http://facebook.com/floweringgoatfarm
Revelations 22:12 And, behold, I come quickly; and my reward is with me, to give every man according as his work shall be.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Track n Go Doc NOT NECESSARILY SNOWCATS Forum 1 04-19-2016 03:15 PM
Wide track imp verses a narrow track imp hunter1951 Snowcat Adventure & Usage Forum 6 01-06-2014 02:56 AM
Tucker Brochures (Belted Track & Terra Track) Melensdad Snowcat History, Articles, Manuals, Brochures & Recollections Forum 8 07-09-2012 07:01 PM
Track N Go the old trucker Tracked 4X4 Vehicles Forum 10 05-07-2012 11:34 AM
It has a track peter keg NOT NECESSARILY SNOWCATS Forum 0 02-21-2010 04:41 PM
