CAD Strikes yet again !
nixon
Boned
Murph , that turbo name comes from the way the air intake is designed . Kinda works on the same principle as Bagless Vacuums . If Your saw predates the Purchase by Husqvarna , that may be one of the reasons they Bought out J'red . It's a great system !
Cowboy
Wait for it.
Stoopid question for you chainsaw experts. :doh: WTF do you guys use to cut dead trees down with that wont destroy the chain before making one cut, I'm talking about is there a special chain/bar combo that would work better. :unsure:
Keep in mind I am a cheap bastard, and dont use the best equipment as far as saws. :wink:
nixon
Boned
You are looking for Semi chisel chain . It's not as fast as Full chisel , but it tolerates dirty wood much better . If You can find it , Stihl RMC chain is probably the best , but also a bit pricey . If You can't find that , go to
www.baileysonline.com look for woodland pro chain . I use that chain a lot , and I'm very happy with it.
BTW ,If You're cutting old locust ,or Osage, nothing lasts long in that stuff .
Cowboy
Wait for it.
Cool , thanks for the info I'll see what I can find on Baileys site. :wink: And Yup its mostly big ass old locust with them huge friggen thorns, and some osage range , its just as bad cuz there full of barbwire. :doh:
nixon
Boned
Look at it this way ,once You get it cut and split ,You won't have to cover the stacks . That stuff could lay in a swamp for 30 years and never rot . I'd love to get into a stand of either of those woods . the only downside to Osage is that it does love to put on a show of sparks . As far as the wire .... Nothing will help with that ,just have to be careful .
Hey , I just got one of My brilliant ideas !!!! I'll send You 10 chains for Your saw , You send Me 1 cord of Osage . Doesn't even have to be split !I prefer 16" lengths , but will accept 18 " .
How's that for a # 1 good deal there GI ?:yum::yum:
Cowboy
Wait for it.
Sounds like a heller deal to me, lemme guess I pay the shipping for the wood? :yum:
nixon
Boned
That IS a heller deal. :yum:
I hope that You don't think that this is a special deal just for You . I've made similar offers to many folks . Mind You, the amount of chains that I send is commensurate with the quality of the wood sent back .
I've only been burned once , Muleman sent Me a box 4x4x8 ' of white oak saw dust . Cost Me two rusty , rocked chains to find out He was less than honorable to deal with .:yum:
Cowboy
Wait for it.
:rolf2:
thcri
did some looking up on that turbo and it may have nothing to do with the motor but the air filter system. I wish I could get to my manual. so Nix you might have right.
http://www.jonsered.com/us/east/chainsaws/cs-2238-s/
nixon
Boned
Just got the 372 back . It's a horse .. running an 8 pin on it with a 20" bar .
nixon
Boned
8 pin? I imagine it has something to do with the chain. Enlighten a rookie here.
Kinda hard to explain . some saws have a clutch housing with a sprocket that is integral to it (spur sprocket )
Some have a clutch housing that has a separate and free floating sprocket to drive the chain . generally it's 7 pins ,or teeth . to pull an 8 pin with authority , there has to be a lot of extra power available .
http://www.oregonchain.com/pro/products/sprockets/pro_main_sprockets.htm
The first is a spur sprocket , the second is rim sprocket system . most saws that run that system are using a 7 pin sprocket .
Clear as Mud
Mind You , If you are running an Ms 290 /390 like Kirk does ....... it's all immaterial .... those tings won't pull a greased string out of a dead cat's ass any way .
nixon
Boned
Murph , did that answer Your question ?
Any way ... next week the 044 Stihl goes in for a total rebuild and tweak .
thcri
Well yeah kind of. But like you said "kind of hard to explain " it is kind of over my head. Ya see, mixed gas, chain oil, sharp chain and that is about all I know. I use my saw twice a year including backing over it with my tractor one year. It survived.
I thought the pin may have had something to do with a chain not the clutch or drive. But more than likely now I will have to investigate mine when I get it out again. So I learned something today.
thcri
Ha the first I read this I don't remember the link being there. Interesting and most helpful when looking at what I have.
muleman
Asshat! When you wake up some morning to a box blocking your drive you will remember your cutting remarks.:hammer::yum: I know
I can get enough conspirators to help me unload it.
nixon
Boned
Hopefully that box will contain either shag bark , Osage , or locust . Mind you, if your in a bind , I'll accept red,or white oak just 'cause you're a reasonably decent guy . :whistling:
nixon
Boned
So, you couldn't get the box down here . Instead you just pushed over the 2 cord stack that I was building ! I went out this morning to witness the mess you made . The only thing worse than stacking is restacking !
YouSir,are despicable !!
muleman
Well if you stack it right to begin with these things don't happen! I have had one stack fall over since I am here and I did not stack it. The wind sure can move things around. I saw a little bit of movement in the new stack in the woodshed yesterday.
muleman
As you can see mine stayed where it was supposed to. Got a long way to go to fill the shed.
nixon
Boned
Yeah, I should have known better than to put the pallets where I did :hammer: .
The weight of the oak on the uneven ground actually twisted the palest enough to cause the stack to fall over . Live and learn , I guess .
nixon
Boned
Yep, you've got a long way to go for sure. Especially with those two piles of poles in the background ! I'm assuming all that's this winters wood . Do you run some type of outdoor boiler ? I only go through about 3-4 cords a year . But then it's a wood stove ,and everything has to be properly seasoned . The seasoning can take 2-3 years depending on the wood . That can be a bit of a pain because it takes up a lot of space . Can't just cut and split it and throw it in the shed and expect it to season .
muleman
Yep on the outside boiler. It is a 6048 central boiler and rated at 500,000 BTU. It will put out the heat if you got the wood to feed it. I burn 2-3 tri axle loads plus some slab wood since I added the greenhouses. It takes a lot of heat to keep them warm with the wind. Still cheaper than oil or propane would be.
nixon
Boned
I've been tempted a couple of times to go that route. Central boiler is about the best you can get from my understanding . But as it is , I only heat the house (approx. 1900 sq. ft. ),and the furnace hasn't run in years other than to see if it's still there. So I stick with what's been working .
muleman
Hot water can be used for a lot of applications. Mine melts my snow and heats my domestic water also. I had it heating the waterers in the barn when we kept critters year round. I have a coil in the air handler and pex under the basement slab and upstairs floors as well. If I want to sit around naked in 90 degree heat I can!:yum::yum:
