Can anyone ID this bombardier Snowcat?
d0n
I have a chance to buy this but being a snowcat newbie, I have no idea what it is exactly or what I should offer for it.
It is a 1972. That much I know.
Any advice and insight would be greatly appreciated.
thanks
MNoutdoors RIP
That should be a Bombardier SW48 or 54 depends on width SW stands for sidewalk and that's where they do best on level sidewalks they will do OK up to about 18" of snow then they loose there ability to turn well they do not stay on top of powder snow about 5000 pounds with 14.5" wide tracks
should have 251 Chrysler Industrial engine and a 3 speed manual tranny part s are still available @ mn-outdoors.com
price 2500-3750 unless cherry then more maybe
thanks
d0n
thanks. Would that price range include attachments suck as a plow?
would this be a better alternative to plowing a driveway than say, a jeep or a 4wd quad?
MNoutdoors RIP
Yes, that would include it. they will do way better than a quad, and also better than a pickup. we have seen them on E-bay go for a little as 1000.00
but will need some work. they are tippy stay on the flat.
$2300 for a redone unit seems to be a pretty good price. Like boggie, I've also seen them as low as $1000 on Ebay, but those are usually pretty rough. $2000 to $3500 is more likely for a decent to good used unit.
Do not confuse these with snowcats. These are designed for use on flat, smooth asphalt or concrete and are used to clean off sidewalks. Taking them out in the woods or the snow is possible but they are typically very narrow and can fall over onto their sides very easily. A snowcat is designed for off road travel in steep or uneven conditions and tipping them is actually a challenge.
If your goal is to clear a driveway then this might be a really good choice for quick work as long as it does not have the "V" shaped plow that many of them are equipped with.
d0n
the sw48 weighs 5000lbs without any attachments? I ask becaise my trailer is somewhat light duty and only 4x7 feet with 14" wheels and a single axle.
Too light wieght for this sw48?
A typical single axle trailer has a 3500# capacity. That 3500# INCLUDES the weight of the trailer!!! So deduct 750-to-1000 pounds and you have a trailer that will carry about 2500 to 2750 pounds. If you look up trailer specs and trailer construction, they are rated on the axel strength. A normal trailer will have a 3500# axle. A normal Dual Axle trailer will have 2 of those axles. I know of no heavy duty single axle trailers. A heavy duty dual axle trailer will have 2 axles rated at 5000# each or go up to 3 axles.
FOR EXAMPLE: My trailer is a 7000# dual axel trailer, weighs about 1500# so it has a capacity of roughly 6000#.
You will need a Dual Axle 7000# trailer, at a MINIMUM to carry the SW48.
Not a problem. Happy to help. If you have other questions we have a lot of folks here who know a heck of a lot more than me.
I have a bit of experience trailering my snowcat, cars and tractors. I've done a lot of digging into trailering issues and requirements, there is a whole lot of confusion over trailer capacity and even towing capacity of vehicles (which typically don't tell you that you have to subtract the weight of your occupants and cargo from the rated capacity).
aulen2002
Looking at the space between the seat and the outside of the cab I'd agree it's a SW model. I think the J5s are around 4k lbs so I suspect the SW models (being smaller) would be lighter, around 3500 lbs. (?) without plow.
Definitely need a dual axle.
I don't have the spec's on the SW series, but they were made heavy so they would have plenty of traction on the sidewalks and streets. The J5 units are much wider and designed for off road use like pulling logs so they also need some weight to them for traction in all sorts of conditions but the little SW 45/54 units were small, tall, narrow and heavy and purpose built. It would not surprise me if they weighed more than a J5. Boggie would probably have complete specs on both the J and the SW units, if he is on line he might be able to give us weights on each unit.
MNoutdoors RIP
Bob, you are correct the SW48/54 Do weigh more than the open cab J-5
The open cab J5 with the head protector 4,126 pounds This is a older J-5
but with the heavier tub 3/16" there is also a older version with 10 gage tub that was lighter3750# then there is also a newer with the Ford 250 in line that is heavier. 5200# and finally the Brand new hydrostatic J-5 is 6800#
as with most Bombardiers they most of the time list them as dry weight and without and accessories.
Now the SW64 or J-5 with three Man cover cab weighs in at 5815#without blade 6430#with the blade both dry weighs. and we have a SW64 with the ford 250 also from the factory it has 2"solid plate under the machine
up to where the plow mounts and it weighs in at 7200# but it can push snow!
The SW 48 come in at right at 5000 pounds without the blade and you can add 500 for the blade and frame
pixie
Congrats !! That's a sharp looking older machine :punk:
Where do you live that you have snow already ?
We are still worrying about hurricanes, here !
Crash
Bombardier SW48 or SW54
A beauty that one is.
Photo gallery (148 photos & growing) of Bombardier sidewalk plows & other tracked vehicles showing the year and asking prices (some are ridiculous) follows - it will give you an idea of the history of these unique machines and the changes in their design:
http://s74.photobucket.com/albums/i250/PEGAZUS44/Sidewalk plows/
The replies above this one have provided EXCELLENT information.
Replacement tracks can cost four grand a set.
CAMOPLAST bought out the Bombardier creatures.
I have the specifications regarding the 1967 SW48 & SW54 variations in a PDF file if you want. PM me if you want a copy.
MNoutdoors RIP
nice collection of photos, I recognize about 25% of those machines as being here before even saw Lnydon's old J5
pixie
That's an interesting collection of other peoples photos. Many are labeled incorrectly such as Boggie's Muskeg firefighter being called a J5 and most of the SW 48s ( including one belonging to a close friend) being labeled as SW54.
The majority of SWs are 48s.
Crash
Re: Bombardier SW48 etc gallery
The photo gallery needs work, I agree. Thanks to the feedback, this thread and others, I can correct it. The photos helped me to look for a deal. Came close to buying the green windowless 1984 two years ago.
As my 660 Yamaha ATV with rear chains (& teeth) does what I need for plowing and logging for 90% of the winter, a SW48 is hard to justify. I'm on 8 acres and harvest wood only for my own needs. The laneway is only 300 feet long. Trails I make in the woods for logging are made with a 60 inch blade (same width as a straight SW48 blade). The SW48 straight blade height is 26 inches though. If the deep woods snow exceeds the ATV's capability, the felled trees disappear when they land anyway, LOL.
I do expect to buy a pre-1975 SW48 someday, and have located parts suppliers and repair facilities in Eastern Canada.
le loup
Six of the pics in your bucket are of my Sw, would you be kind enough to take them out of there, I would not mind so much if you had taken time to ask permission to use them , you did not. You also did not label them correctly , you have named my SW48 as an SW54.
