I need to recondition the front (3 acre) pasture on my old ranch . I just finished digging out the last tree stump , picking up 30 zillion miles of used barb wire and misc metal that was disgarded carelessly by the privous owner .
I have lots of ground squirrels( hundreds) in this pasture . It has made the field extremely rough, bumpy and dangerous for cattle or horses with all the holes . A 22cal.rilfe is now taking care of squirrels every evening .
I also dug a small pond with a island in the center and used the excess dirt to fill low spots that the old stream had cut through the pasture over the last 50 years .
I have mowed the pasture with my Brush Hog down to about 4 or 5 inches . I tried to use my tamden disc ,but it will not even begin to cut through the thick 4" plus grass matting even with weight applied .This pasture has not been maintained in upteen years .
I am thinking I need to rototill or plow under and then disc to get a good base to plant the new White Clover for my Elk .
I do have access to a old D2 Cat crawler with a angle blade that has been completely rebuilt if neccessary . It will peel the grass mat up .
I can use any suggestions any of you old farmers/ranchers can think of .
I would like to rebuild this pasture in the fall and try to get some cover on it before the winter snows .
Thoughts or opinions greatly appreciated .
