I'm having a problem with my Baja. It has a 454 (7.4L), normally runs perfect. It ran fine, then out of nowhere would not start. Checked and it is getting plenty of fire. Checked the carb and it's dry. Primed the carb with a little gas and she fired right up. Ran fine, I ran it for 1/2 hour, then it started up enough for us to get 100 yards from the dock then it died. Same problem. Primed the carb and it ran just fine.
I plan to change the water seporator and the fuel filter, since those need replaced anyway and are the cheapest fix.
Have any of you heard of a fuel pump going out that would act that erratically? Any other ideas what might be wrong?
