Ok, Came home to no water. Inline pressure gauge reads zero. Check the breaker it is on. Bypass the pressure switch and nothing happens. Could be the pump right? Yank the pump then pass out. Replace the pump, find a broken hot wire and a broken ground wire. Repair everything test the pump and it comes on. Put it all back in the ground ,turn it on the pump hums but doesn't pump any water. Do I have to try an prime the pump though the Bit Coupling? Running out of ideas...Anyone out there mess with well pumps? Thanks!
