Spryte 1301 Brake Cable
Well this weekend I broke the emergency brake cable on BALTO. The swaged end broke off right at the lever / linkage connection to the cable. Any advice on how to replace / repair would be real helpful. Thanks
redsqwrl
This is a bit of work, but I have been know to shorten the casing and recrimp the end back on.
Provided you have the old crimp/swage. drill or punch the old cable out.
Nip the casing off a bit to get some length.
Smooth everything back out.
Crimp.
Hope.
Necessity is the mother of invention.
JimVT
I'm not sure what it is like but some of the larger boat places make heavy cables.
jim
find a morse cable vendor take the old one off have them build up a new one that will move freely
Thanks dds-
I trust you have a stash of fuel in case those boyz don't get through the ice soon...remember Jack Daniels will freeze at about 27 below so keep it in a cooler for insulation.
I'll have to pull the old cable out of the sheath, measure and make a replacement, then hope I can re-insert in the sheath (because the sheath makes a penetration into motor compartment and then out to the drive train enclosure that runs back to the OC-4...remember this is a 1301 amphibious machine and everything is sealed / water tight)...
I'll try Morse cable once I get the old one out.
cheers
