Reply
Thread Tools Display Modes
  #1
Old 09-10-2019, 09:04 PM
Jphoenix's Avatar
Jphoenix Jphoenix is offline
Jphoenix is on a distinguished road
Default NAPA 30 wt TO-4 hydraulic fluid?
Closest fluid I can find for my diff is 5 gals of the NAPA brand TO-4, is this going to work ok in my SV200? Will 5 gals fill the diff housing?
Thanks.
__________________
Jim Phoenix
www.jimphoenix.com
“For a little more, you can do it yourself”... Ed Hollingsworth
  #2
Old 09-11-2019, 11:02 AM
MNoutdoors's Avatar
MNoutdoors MNoutdoors is offline
Tracked Evolution Central
MNoutdoors is on a distinguished road
Default Re: NAPA 30 wt TO-4 hydraulic fluid?
Quote:
Thanks.
It will work, 5 gallons should just do it 4.75 gallons normally
Amsoil powershift is very good in 30 or 50 weight
Cat T-04 also works well in 30 or 50 weight
We have found the steering response slightly better with the amsoil
__________________
What ever happened to the good old days
The Following 4 Users Say Thank You to MNoutdoors For This Useful Post:
Jphoenix (09-11-2019), longbed454 (09-11-2019), olympicorange (09-11-2019), Taxrulz (09-11-2019)
  #3
Old 09-11-2019, 09:55 PM
Jphoenix's Avatar
Thanks, I ordered a bucket of amsoil 30wt. Free shipping
__________________
Jim Phoenix
www.jimphoenix.com
  #4
Old 09-11-2019, 10:07 PM
zspryte zspryte is offline
zspryte is on a distinguished road
Is Cat the only place to buy Cat T-04 oil from?
  #5
Old 09-12-2019, 07:26 AM
olympicorange's Avatar
olympicorange olympicorange is offline
olympicorange is on a distinguished road
Quote:
….. there's lots of companies that make a ''compatible'' TO-4 oil, but CAT was the first to ''spec'' it out , in a broadband useage…. has great ''inhibitors'' to guard against pump wear...
  #6
Old 09-12-2019, 07:58 AM
MNoutdoors's Avatar
Quote:
Also, Both the Amsoil and the Cat fluids both have friction modifiers which, in the off brands I’m not sure.
It’s kind like beer, you know there’s beer,then there’s BEER! They are all beer but!
Some are just better beerDon’t me started on Snowcats!!!!
__________________
The Following 2 Users Say Thank You to MNoutdoors For This Useful Post:
Jphoenix (09-12-2019), rockhead (09-12-2019)
  #7
Old 09-12-2019, 02:28 PM
Dr. Zaugg Dr. Zaugg is offline
Dr. Zaugg is on a distinguished road
you can also use John Deere's HY-Tran tractor hydraulic and transmission fluid for the same reasons Brad mentioned. Use the best oil you can get and stay away from "off brand" oils. They will ultimately cost you.
  #8
Old 09-13-2019, 08:13 PM
Jphoenix's Avatar
Ordered a bucket of amsoil on Wednesday and it’s here today, that’s fast!
__________________
Jim Phoenix
www.jimphoenix.com
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
OC-12 Differential Fluid & Hydraulic System Gren THIOKOL/LMC/DMC Technical Issues Forum 5 08-24-2018 09:10 AM
Ford 550 backhoe leaking hydraulic fluid wildskies.com Tractor Forum 2 03-14-2014 08:26 PM
Hydraulic fluid ~ got the bleeding stopped Melensdad Tractor Forum 7 06-17-2010 07:53 AM
NAPA Transmissin Fluid. dennytodd Snowcat Repairs, Parts & Problems Forum 11 12-29-2008 04:14 PM
ATF Dextron III vs special hydraulic fluid srexecmark Snowcat Repairs, Parts & Problems Forum 14 09-28-2007 11:51 PM
Powered by vBulletin® Version 3.8.9
Copyright ©2000 - 2020, vBulletin Solutions, Inc.
Copyright © 2002 - 2020 www.ForumsForums.com
