Go Back   Forums Forums - Off Topic Forum FUN > Vehicles > Motorcycles & Accessories Forum
Reply
Thread Tools Display Modes
  #1
Old 06-04-2019, 09:43 AM
Melensdad's Avatar
Jerk in a Hawaiian Shirt
Default Added some running lights to the motorcycles
Did my first night time test ride with the new auxiliary lights installed. I'm not much of a night rider on the bike, preferring instead to ride during daylight hours. These lights were added for added visibility during both night & day riding.
The lovely Mrs_Bob has identical front lights and a similar but different rear set up because her cargo boxes have integrated lights built into the boxes.
FRONT: DENALI brand "DRL" model LED running lights
The front lights are small LED light bars, located on each side of the front wheel, near the axle. They have a widespread beam and are designed to make the bike seen by oncoming drivers without blinding them.
The beam pattern spread is 180 degrees so they light up the front wheel and the ground around the motorcycle at night making the whole front end very visible. During the day they are bright enough in direct sunlight to be easily seen from the front or the sides.
REAR: Lighted license plate frame
Not as bright as the front lights but it gives some added visibility and is multi function. Technically this is legal to run instead of running dedicated brake, running and turn signals so it can be used as a stand alone unit but I wanted it added for more visibility. The bike's brake and running light is substantially above the license plate so this gives the back of the bike a High/Low light pattern with the lighted license frame.
  • WHITE LIGHT to increase visibility to the license plate.
  • RED LIGHT under the license plate is a dual intensity light module.
    Functions as a secondary Running light at normal intensity.
    Functions as a secondary Brake light when the brakes are applied.
  • AMBER SIDE LIGHTS function as secondary turn signals
__________________
- Ayn Rand
The Following User Says Thank You to Melensdad For This Useful Post:
jim slagle  (06-04-2019)
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Anyone else here love old Japanese Motorcycles? TiredRetired Motorcycles & Accessories Forum 7 08-06-2018 10:10 AM
Ural 2WD motorcycles w/sidecar Melensdad Motorcycles & Accessories Forum 6 10-17-2016 07:33 AM
Why German motorcycles are the best Catavenger Open Forum 2 05-01-2012 07:56 AM
New motorcycles JimR Motorcycles & Accessories Forum 4 12-12-2007 09:22 AM
Motorcycles I've owned Eric L Motorcycles & Accessories Forum 42 11-17-2007 05:27 PM
Powered by vBulletin® Version 3.8.9
Copyright ©2000 - 2020, vBulletin Solutions, Inc.
Copyright 2002 - 2020 www.ForumsForums.com
