Reply
Thread Tools Display Modes
  #1
Old 03-30-2019, 07:06 PM
Kmcbride Kmcbride is offline
Junior Member
Kmcbride is on a distinguished road
Default DMC 1450 Idler help
Iím putting my Snowcat back together finally and need a little help. Is there a torque for the front idlers or just a ďruleĒ to follow on how tight they should be? Canít find it anywhere in the bits of manuals that I have and Iíve searched the threads. Canít find anything and would like to get this done by dark. Iím new at this so please be kind. Thanks.
  #2
Old 03-30-2019, 07:12 PM
MNoutdoors's Avatar
MNoutdoors MNoutdoors is offline
Tracked Evolution Central
MNoutdoors is on a distinguished road
Default Re: DMC 1450 Idler help
Quote:
Tighten till no slop better a little on the loose side than to tight
__________________
What ever happened to the good old days
  #3
Old 03-30-2019, 07:20 PM
MNoutdoors's Avatar
Better clarify that after rereading your post, if you mean bearings then follow my post, if you mean track tightness then thatís different. Tighten the track till snug then drive it a little bit and have someone watch the track when you put into reverse on a flat surface. Look at the area between the sprocket and the rear wheel for curl a slight curl is ok, a big dish plate sized curl is to much.
__________________
The Following 3 Users Say Thank You to MNoutdoors For This Useful Post:
Kmcbride (04-02-2019), rockhead (03-30-2019), sno-drifter (03-30-2019)
  #4
Old 03-30-2019, 10:15 PM
Junior Member
Thanks Brad, you would know this cat better than anyone since it used to be yours . Yes, itís the bearing. Iíll just tighten them snug then. Thanks again.
  #5
Old 03-31-2019, 09:12 AM
redsqwrl's Avatar
redsqwrl redsqwrl is offline
redsqwrl is on a distinguished road
My handicap is wheel bearings.
use a search engine (google) for dexter they have great write ups on the process of setting tapered roller bearings for their trailers...
  • some processes have you achieve a torque value don't turn the wheel then back off to the next keeper position.
  • other bearing processes tighten hand tight, then turn the wheel <each direction> and then loosen.
  • A VW service manual for the rear of a jetta states tighten until it takes 20 foot pounds of force to slide a washer beneath the nut.
In my slow and back in time cognitive function, I run bearing a little tighter on the sno cat and snow cat(s) than i do on my trailers.
The Following 2 Users Say Thank You to redsqwrl For This Useful Post:
Kmcbride (04-02-2019), sno-drifter (03-31-2019)
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Tucker idler wheel options... Blackfoot Tucker Snowcat Repairs, Parts & Problems Forum 2 10-31-2018 09:55 PM
Tucker idler wheels Track Addict Snowcat Classifieds (For Sale / Wanted) Forum 0 03-25-2015 07:54 PM
Idler wheels? Manistee Snowcat Repairs, Parts & Problems Forum 7 06-27-2013 07:31 PM
Idler Wheel Problem Manistee THIOKOL/LMC/DMC Technical Issues Forum 3 05-29-2013 01:26 AM
1983 bombi 5 idler wheels brianf Snowcat Adventure & Usage Forum 1 05-03-2007 09:16 AM
Powered by vBulletin® Version 3.8.9
Copyright ©2000 - 2020, vBulletin Solutions, Inc.
Copyright © 2002 - 2020 www.ForumsForums.com
