Reply
Thread Tools Display Modes
  #1
Old 08-05-2019, 08:57 PM
Jphoenix's Avatar
Jphoenix Jphoenix is offline
Jphoenix is on a distinguished road
Default SV200 windshield seals
I’m going to remove the glass from my SV200 in order to refinish the cab, are the seals standard items I can buy from someplace? They appear to be the same rubber seal cross section front and rear, would to buy a suitable length of it for all four windows.
Any info or leads appreciated.
__________________
Jim Phoenix
www.jimphoenix.com
“For a little more, you can do it yourself”... Ed Hollingsworth
  #2
Old 08-05-2019, 09:46 PM
MNoutdoors's Avatar
MNoutdoors MNoutdoors is offline
Tracked Evolution Central
MNoutdoors is on a distinguished road
Default Re: SV200 windshield seals
We buy ours here
http://www.crlaurence.com/
Check if yours is 1/4” or 5/16 center web thickness using the wrong one can make the install a real PITA
__________________
What ever happened to the good old days
  #3
Old 08-05-2019, 09:53 PM
Jphoenix's Avatar
Good info, thanks!
__________________
Jim Phoenix
www.jimphoenix.com
  #4
Old 08-05-2019, 10:07 PM
MNoutdoors's Avatar
This will get you a little closer
http://www.crlaurence.com/apps/sites...ndow%20gaskets
__________________
The Following User Says Thank You to MNoutdoors For This Useful Post:
olympicorange (08-06-2019)
  #5
Old 08-05-2019, 10:13 PM
Jphoenix's Avatar
Thanks, that’s a mighty big website, I was a bit lost. Do you sell lengths of the correct seal? I’ll have to remove it and and get a measurement.
__________________
Jim Phoenix
www.jimphoenix.com
  #6
Old 08-05-2019, 10:18 PM
MNoutdoors's Avatar
Quote:
Your better off ordering a roll, you will need it if your doing all the windows
Better get a install tool too.
__________________
Jphoenix (08-05-2019)
  #7
Old 08-05-2019, 10:26 PM
MNoutdoors's Avatar
This tool is invaluable, makes it almost “FUN” almost
http://www.crlaurence.com/crlapps/sh...ID=20896&pom=0
__________________
  #8
Old 08-05-2019, 10:32 PM
Jphoenix's Avatar
Cool, having the right tool is important. Thanks again!
__________________
Jim Phoenix
www.jimphoenix.com
  #9
Old 08-06-2019, 05:25 PM
redsqwrl's Avatar
redsqwrl redsqwrl is offline
I can't agree more, buy a roll.
I have become a source around here, I sell the extra to my lazy buddies, which in turn funds mine...... I have sent some to lazy ff members.
lazy equals smart.......
I am struggling to recall the website i found that was cleaner to find the product at.... If I stumble across it I will post it.... it was something like auto trim or some such
The Following User Says Thank You to redsqwrl For This Useful Post:
Blackfoot Tucker (08-07-2019)
  #10
Old 08-07-2019, 05:17 PM
Blackfoot Tucker Blackfoot Tucker is offline
Blackfoot Tucker is on a distinguished road
Quote:
Good advice!
I would suggest measuring your windows to see how much you need, and then buy a single roll with at least that amount of window gasket. That quantity may be more than you want, but the problem with shorter lengths is you tend to have a lot of waste as you want one one length to do each window, not multiple pieces for a single window. Suppose you have four windows that need 14' long pieces each. That adds up to 56'. Two 25' lengths and a 10' wont work, a 50' and a 10' won't work either.
Unless they've changed policies, CR Laurence won't sell to "the unwashed masses", better known as individuals. You need to be a business, or at least you had to be when I tried to buy from them.
You can, however figure out the CR Laurence part number and then Google that. There will very likely be other companies that retail that same product. I've done that successfully.
  #11
Old 08-07-2019, 05:21 PM
Jphoenix's Avatar
Good points all, I shall do as suggested, thanks guys!
__________________
Jim Phoenix
www.jimphoenix.com
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
wts--sv200 topwelder44 Snowcat Classifieds (For Sale / Wanted) Forum 9 08-30-2017 08:00 AM
cover your windshield before towing brianf Snowcat Restoration & Modification Projects Forum 0 08-25-2011 05:23 PM
Need a wildlife sticker for your windshield? jim slagle Junkman's Corner 6 09-07-2008 09:18 PM
Windshield Pricing Doc Cars, Trucks Forum 8 09-27-2006 06:32 AM
Bug on the windshield TOMLESCOEQUIP Jokes_Forum 0 01-10-2006 01:20 PM
Copyright © 2002 - 2018 www.ForumsForums.com
