T-16 rear end what type of oil?
caldonia
Working to get my '71 Nodwell FN 15 up and running for the season. What type of oil should I use in the T-16 rear end?
amzoil power shift has worked well in all steering axles I have used it in. otherwise a to-4 type hydraulic oil with that has a friction modifier for wet disc clutches
caldonia
Amzoil Powershift it is. Sould have it here in a day or so. finally got some snow on the valley floor. Hope to be up and running soon. Will post some pics soon.
Trackrig
I haven't used Amzoil Powershift, but what the mfg will tell you to use is a straight mineral oil. Chevron, Lubriplate and Cat have it. If you use a standard gear lube, after a while it will put a glaze on the steering brake pads and that's then end of making it turn. You can take them out and rough them up with a wire wheel on a small side grinder, but that's just a temporary fix.
Bill
