Anyone here ever been into a compact tractor rearend ?
I finally got a chance to tear into my iseki to find out what was causing it to lockup in reverse . I figured worse case scenerio I,ll part it out since I dont seem to be able to find any parts for the friggen thing .
I knew when I screwed it up & happened to be digging in my pond when it all of a sudden would not move backwards & made weird popping noises . So Long story short I couldn,t go forward because I was at the peeper end . I walked it backwards out untill I could turn it around & drive out . I also did the same thing to get it backed into my shop so I was expecting to find at least some broken gears or shafts if not worse .
The only thing I can find wrong is 7 out of 8 third member bolts are broke off where the nut goes on . I fished out the lock washers & 5 nuts but still missing two . There seems to be no damage to anything else but I will at least have to tear apart the whole right axle assembly to get the ring gear bolts out & replace them . 1 bolt is still tight which saved it from more damage .
Anyway I have no manual for it & cant find anything online that shows the breakdown pics . The only forum that has any Iseki information has allways proved to be worthless to me so I,m here asking for any input once again . It aint rocket science but I know that the brake is in there as well as the differential lock so if anyone has had any experience I would sure appreciate any input .
here are some pics of where I,m at on it as of this moment . Thanks in advance .
